1bb_y
So currently I am in the process of retrofitting the Audi TTS steering wheel pictured above onto my A3 8V. I have also been following this this thread for help with wiring the airbag.
So it turns out not only is the connector on my steering wheel different to the one from the thread or any other TT8S steering wheel I have seen, but the airbag wiring connector is also different and doesn't work with my car.
As you can see my steering wheel has a T4 connector when it should actually have a T6 connector which means my steering wheel buttons will not work
And as you can also see here on the left is the original airbag connector on the right is the TT airbag connector which are quite different.
Clearly not all of the TT8S steering wheel and airbags are the same and I have no clue how to move forward. Does anyone know if I can change the wiring harness on the steering wheel and airbag and the part numbers?
