You don't need to fit a VR6 MAF tube... it will ****** the map big time if you did anyway and would need to be 're' mapped so the ECU knows what to do with it... larger MAF tube will slow airspeed and so the ECU will actually see less airflow as the scaling will be out..
Ok cool will just pack it up with the rest of my bits for the ko4 conversion cheers tuffy was thinking of using the jetex filter but I will need to fit the vr6 maf !
Got a large 80mm cone one with extension hose for just £30!! Got to love eBay also picked up vr6 clutch and flywheel for only £60!! Only done 2.5k ko4 here I come !!
