Cockney Boy
- Joined
- Nov 26, 2007
- Messages
- 482
- Reaction score
- 6
Hi Folks,
Got a fult code pop up on the Q7 a few days ago. Its says that my Transmision Cooler valve is short to ground. (Fault code P2754)
I have tralled the web for hours with no joy. we also spend a good hour under the car looking for any valve of sens or relating to the oil cooling circuit.
Address 02: Auto Trans (J217) Labels: 0C8-927-750.clb
Part No SW: 0C8 927 750 AE HW: 0C8 927 750 AE
Component: AL1000 AISIN 001 1815
Serial number:
Coding: 001578
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_TCMAL991031 001001
ROD: EV_TCMAL991031_001.rod
VCID: 6FE6642EB6D83E3A55-803A
1 Fault Found:
12754 - Valve for Transmission Fluid Cooler
P2754 00 [143] - Short to GND
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Reset counter: 44
Engine speed: 0.0 /min
Transmission input speed: 0 /min
Transmission output speed: 0 /min
Engine torque: -76 Nm
Transmission fluid temperature: 10 ∞C
Accelerator position: 0.0 %
Clutch status: Open
Clutch status: Open
Clutch status: Open
Clutch status: Open
Clutch status: Open
Clutch status: Open
Clutch status: Open
EOP failure status: Normalcy
EOP target revolution: 0 /min
EOP actual revolution: 65279 /min
Engine Speed signal Current: 65279 /min
EOP failure status with EOP without HV: Motor normal stop
EOP target current: 65278 mA
Any ideas on where it could be?
Rich
Serial number:
Coding: 001578
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 44
Clutch status: Open
Clutch status: Open
Clutch status: Open
Clutch status: Open
Clutch status: Open
Clutch status: Open
Clutch status: Open
Rich
