A while ago I had stretched a pump across the car to refuel. When I removed the pump there was a crack and several plastic rings came away and were left around the pump nozzle.
The result was I had to get a specific angel on the pump when refuelling to avoid it cutting out. So not a big problem.
About 2 weeks ago I was refuelling and a further piece of plastic came off - this time it fell down the neck of the fuel tank. Since then fuel pumps will cut off unless I'm barely squeezing the trigger - 5+ mins to put £20 of diesel in plus a cramping hand from trying to barely put any pressure on the trigger.
Local Audi guy advised fishing the piece out with some wire, which I am going to attempt today. If I can then start refuelling more normally then all is good in the world but I fear it might not be that simple.
Does anyone know if it's possible to replace the missing parts in the fuel tank neck? Dealer advised I probably need a new fuel tank for £1000+
Thanks.
Thanks.
