Puddle & Door Lights eBay
I have ordered some plugs if they are correct I will let you no.
Hi guys I fitted mine had 1 issue with wiring pins as they changed after 2008.
But other from that all working perfect.
Next 1 is stereo/steering wheel and rns-e bluetooth unit.
Reactions: samuelh_888 and maxpayne
What was the specific issue and how did you resolve if you don't mind me asking? I'm looking to do this soon (I have a MY61) - Cheers!
It's the pins I 18 and 19.
On 2008 up they use pins 1 and 2.
I bought I plug from a car he scrapped and used the pins out of that.
I bought the loom and light of eBay.
When it gets dark tonight I will take pics
May 2007 was change over do pin 18 and earth on pin 19. Mine is a 57 8p I used these pins.
May 2007 was change over.
Pin 18 live feed and pin 19 is the earth.
On mine I had to use these pins.
Here is what my front 2 doors look like.
Am trying to get custom names for rear for my kids.
Looks good @GeForce>XI<, I think I'll put S3 in the front.
You have a Sportback, in VCDS do you need to activate for the rear doors too, so for all four doors it would be 44, 54, 64, 74 or did you only need to do 44 & 54?
I suspect the 32pin plus is already in place? Sorry I haven't removed door cards yet to check.
Thanks once again
Nice write-up mate. Just to confirm this is for all 4 doors? Cheers
Just changed to all my 4 doors with AudiSport projector and replaced red reflector with red LED.
Looks pretty good.
Looks pretty good.
Can you link the dupont connector you bought? I can’t seem to find the correct length for some reason.
2.54mm, but unable to find 13.4mm in length.
cheers
