Protector for rubber seals and rubber trim
CKAJCA
Member
Alicante
I live in Spain and would like recommendations for a protector for rubber seals and rubber window trim. The sun destroys plastic and rubber in no time if it is not protected from UV light.
I recommend CarPro CQUARTZ DLUX, which is a protective coating designed for plastic and rubber. It lasts up to one year, provides strong UV protection, is resistant to very high temperatures, doesn't break the bank, making it an ideal "apply and forget" kind of coating. Make sure the plastics and rubber in question are as clean as possible before application for best results.
Reactions: enc, CKAJCA and Jassyo06
I was going to recommend Swissvax Seal Feed its expensive but a bottle lasts for years ie 5 years at least
Reactions: Scotty75 and CKAJCA
I second that , seal feed is the absolute best . Even if it is a bit expensive
Reactions: CKAJCA
Chemical Guys trim and tyre gel is a good value buy and lasts well
Reactions: CKAJCA
I use autoglym rubber and vinyl care, reasonably priced and lasts a decent amount of time
Reactions: CKAJCA
just to add to this had the same problem and Autofinesse Dressel brought me the best results
Reactions: CKAJCA
I live in Spain and would like recommendations for a protector Showbox jiofi.local.html tplinklogin for rubber seals and rubber window trim. The sun destroys plastic and rubber in no time if it is not protected from UV light.
Reactions: CKAJCA
