Hi everyone. Our 2007 2.0tfsi 8p started lighting up the dash with errors. I have both VCDS and also a bluetooth dongle with Carista on my phone. Carista started reporting the following:
Typed out for the benefit of anyone searching for these codes having a similar issue:
P0441
00287
00778
00796
VCDS Output:
I then hooked up VCDS and had a play around, it was a few weeks back but I managed to stop the PAS working (not my finest moment). So now, we have four yellow dash lights, no ABS or power steering (my wife loves it..) and an MOT due!
My research is pointing to a rear right wheel bearing, or the ABS sensor, or maybe the ABS pump which looks pretty expensive.
What's going on here and how to proceed? :S
P0441
00287
00778
00796
VCDS Output:
Code:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 76
VIN: WAUZZZ8P17A201927 Mileage: 224400km/139435miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8P0 907 115 K HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0040
Revision: 5BH16--- Serial number: AUX7Z0G3FN211I
Coding: 0103000318070060
Shop #: WSC 06314 000 00000
VCID: 3A7BD46375AA42CE9A7-806F
No fault code found.
Readiness: 0010 0001
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021122
VCID: 73E539471240F386991-8026
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AC HW: 8P0 820 043 AC
Component: KlimavollautomatH19 0360
Revision: 121749 Serial number: 8P0820043AC
Shop #: WSC 00000 000 00000
VCID: 6DD12F3F746425764F5-8038
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H43 1201
Revision: 00H43000 Serial number: 00000006916382
Coding: A10C5E07E014100000000000000000000009FE175C0100
Shop #: WSC 06314 000 08192
VCID: 408FA68B1376181ED43-8015
Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
Component: Airbag 9.41 H13 4220
Revision: 91H13422 Serial number: 0037W0G1AZX8
Coding: 0071612
VCID: 479DBD9736582F26159-8012
Subsystem 1 - Serial number: 63328RB4024E6646K
Subsystem 2 - Serial number: 63428RB4024948A0G
Subsystem 3 - Serial number: 63528RB4024E6655M
Subsystem 4 - Serial number: 63628RB4024938029
Subsystem 5 - Serial number: 63729RB4024C4A2AR
Subsystem 6 - Serial number: 63829RB4024C49FE1
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 036 0070
Coding: 0000012
VCID: 78FF0E6B0B2690DEAC3-802D
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 G HW: 8P0 920 981 G
Component: KOMBIINSTR. VDO H20 0570
Revision: D0H20004 Serial number: 2243G004005531
Coding: 0004418
Shop #: WSC 00011 067 57207
VCID: 3C77D27B7F9E7CFE88B-8069
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H12 0170
Revision: H12 Serial number: 33001073200F37
Coding: 3D0F074007000101
VCID: 2F6DF537BEE897663D9-807A
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H20004 Serial number: AUX7Z0G3FN211I
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0090
Coding: 0000560
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.078 H07 1806
Shop #: WSC 02069 000 90108
VCID: 3561C75F5CB4ADB6775-8060
2 Faults Found:
02546 - Steering Limit Stop
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Mileage: 224400 km
Temperature: 15.0°C
Voltage: 14.00 V
Voltage: 13.80 V
00778 - Steering Angle Sensor (G85)
000 - -
Freeze Frame:
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 F
Component: KSG H08 0070
Coding: 9880202002186D098505489AC637
VCID: 3F8DA5776E8867E6AD9-806A
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Coding: 0000560
VCID: 4189A38F187C1116DBD-8014
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 G HW: 8P0 035 186 G
Component: R Concert2+ H17 0240
Revision: 00H17000 Serial number: AUZ1Z3G9146059
Coding: 0000001
Shop #: WSC 00216 210 81315
VCID: 3663C05341B2A6AE7EF-8063
Address 76: Park Assist Labels: 8P0-919-283.lbl
Part No SW: 8P0 919 283 D HW: 8P0 919 283 D
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 00067824820708
Coding: 0000003
End ---------------------------------------------------------------------
