That's In Daylight?!
Pretty sure I can't even see the beam of my headlights in full daylight.
6500k is the Above but not one of my ballasts as the chap had a Hid kit so we fitted projectors and bulbs only.Hey trups, what colour bulbs are the ones in the A4 pic above? Thanks.
there are 2 lots of high beam on this like there will be with yours.
Bixenons are inactive when dipped beam is turned off. (just high beam halogen H7 if Xenons are turned off).If I'm right it means there's the xenon high beam and a halogen 1which is for when just just give someone a quick flash when you don't have your lights on but I could be wrong
so what does this mean???
When your dipped beam is turned off, your high beam is solely just your H7 bulb (halogen or which every type of bulb you choose).I think I understand but not fully... Had to read that post a couple of times to figure out what it meant lol
So basically what we are getting is just the xenon, NOT another set of halogen (as per stock for high beam) ???
Yes, with the Xenons acting as Bixenons when there turned on..What we are getting is the same set up as stock but with upgraded xenons
Don't like the sound of that, looks-wise...they have a blue glass
Aaah, the "you are never allowed to use this except in a situation you will never see in real life" lights Passthey are the 1st click of your headlight switch.
Correct.
Thanks @mark_S3 for clearing it up.
OEM xenons that are on your car are a Low beam projector, the new one is a bi xenon which has a shield assembly inside and I get the feed from the high beam so when you flash that shield will drop in the projector lifting the beam to assist with night driving. So even tho the projectors I'm putting in will be an upgrade you also get the added bonus of the bi xenon function.
Trups
No lights on
Flash lights = Main beam comes on for duration of flash
Side light on
Side lights on permenantly
Headlights on Dipped
Xenon projectors on permenantly dipped
Flash lights = Main beam comes on for duration of flash + Xenon drops shutter and is now main beam too for duration of flash
Headlights on full beam
Xenon is full beam along with main beam on
No lights on
Side light on
Thanks for pointing that out @Tj 0785.
@k7aus that's high beam, low beam shots where too shaken for me to use, £25 for an extra set. These bulbs are great bulbs, @Gops had some from me to replace his kit he bought a few years back and his feedback was the setup at 35w was better than his old setup at 55w.
if you look you can see how sharp the low beam light is along the sides, and you can see the high beam goes fainter as the high beam is pushed forwards leaving the sides illuminated without loosing any output.
This setup was also fitted with out ice white high beam halogen in the OEM location so there are 2 lots of high beam on this like there will be with yours.
