  2. Dismiss Notice
polytek engine mounts
S3_Olly Feb 10, 2015
  1. S3_Olly
    S3_Olly Full Throttle
    253
    Anyone that polytek ' d there engine mounts get a whirring sort of noise when letting off the gas but goes when you put your foot down again?
  2. Avatar
    snack-media
    Advertisement
  3. S3_Olly
    253
    Bump
  4. Prawn
    12,096
    4,331
    Hello mate, just saw your PM about this also.
    The mounts themselves can't make any noise at all, but what they could do is amplify other engine / transmission noises through the chassis due to the increased stiffness.
    It sounds like what you're hearing is a slightly bit of transmission noise.
    Mine is very noisey on overrun, a whirring / whining sound. On stock mounts you couldn't hear a thing.
    Perhaps try and post a clip of the sound incase it's something more sinister?
  5. rupe
    rupe A3 TQS In Devon
    255
    My old golf did what you describe prawn when I done the trans mount, I thought I'd broken something it was that loud, removed it and noise gone.
  6. Scullies
    Scullies Registered User
    1,541
    660
    Mine is terrible with the lightweight flywheel - been thinking about fitting a piece of rubber between the mount and chassis to try reduce this noise as its damn annoying.
    I still have to fit a vibratech gearbox mount, hoping that will make some difference too
    Mrharris2 likes this.
  7. S3_Olly
    253
    Yes tufty mentioned this mate and it does sound like that almost sounds like electrical interference but more mechanical like you say transmission noise amplified but I got a video mate if it will let me upload but you can't really hear it so be patient and thanks for your help.
    Do you think adding something under the mount would help dampen the noise or would it still come from where it's bolted on to the engine rather than the chassis, but I tell you what it's made a big difference and I'm impressed how much difference it made for so little.
    If it gets on my tits then I'll be taking the 85 flex out and putting 70 in it but would that make any difference or not and would it be hard to get the mould out to refill with 70 flex.
  8. S3_Olly
    253
    S3 problem engine mount polytek'd:
  9. S3_Olly
    253
    There you go not the best though lol
  10. daz-20vt
    daz-20vt Registered User
    2,825
    585
    vids not working?
  11. Mrharris2
    Mrharris2 Boost needed
    666
    77
    It's private dude
  12. Avatar
    snack-media
    Advertisement
  13. S3_Olly
    253
    How do you change that lol
  14. Mrharris2
    666
    77
    Go onto your youtube account and switch to everyone can view or someone like that mate
  15. S3_Olly
    253
    Nothing on there regarding that here's the ultimate
  16. JamieT_a3
    JamieT_a3 Registered User
    114
    25
    Still says private , try posting the link to the video ?
  17. S3_Olly
    253
    Haha try that
  18. S3_Olly
    253
    Did that work :)
  19. westcoast a3
    westcoast a3 Registered User
    319
    37
    I saw it yesterday :) I have used 70 shore polytek and it's also quite loud :/
  20. S3_Olly
    253
    Doing my head in there must be a reason for the excessive noise it produces lol
  21. westcoast a3
    319
    37
    I was thinking of drilling some holes to see if it helps but not to sure how safe that is :/
  22. Mrharris2
    666
    77
    Don't drill holes, if it bothers u that much change back to standard bushes?
  23. superkarl
    superkarl MAN OF STEEL
    10,037
    2,677
    that just sounds like something is rattling interior wise to me
  24. flying oyster
    flying oyster flying oyster
    564
    32
    I changed to polytek mounts about 4months ago everything rattles now including my fillings !!
    Dani_B19 likes this.
  25. <tuffty/>
    <tuffty/> Badger 5 Edition...Its all about the flow... Staff Member Moderator
    24,314
    5,588
    Because the engine vibrates and the mounts are solid so transmits this vibration through to the rest of the car... this is why VAG fit floppy mounts...
    The more solid material carries the noise from the engine/gearbox... this is why old skool mechanics like myself sometimes use a screwdriver placed on various areas of an engine to listen for 'issues'...
  26. Prawn
    12,096
    4,331
    Do you just mean the slight whine sound on over run?
    If so, as tuffty says, that's simply a feature of stiffer mountings. Nothing you can do about that, other than remove them and go back to stock!
  27. kwistof
    kwistof South East Events Moderator
    2,433
    539
    Listened to the video last night and bar the first 20 seconds where it sounds something is rattling in the cabin.....everything else sounds normal post polytek engine mounts.
    It's most definitely not OEM feel or noise- but that's never been reported anywhere and I seem to recall creating a thread myself on this forum advising of the additional vibrations/increase in noise
  28. Scullies
    1,541
    660
    FWIW - I removed the gearbox polytek mount today and installed the vibra technic mount. I also cut up an old silicone straight coupler, cut it to the size of the flange that bolts to the chassis and fitted in between the mount and the chassis.
    Much much better.
    The over run noise on my car was really bad, but now I can almost hear myself think while I'm driving :)
    Engine side mount is still polytek, upgraded vibra technic is on the to do list.
  29. SHUk
    SHUk Once Bitten Forever Smitten =]
    357
    27
    Could someone advise me of which engine mounts are worth there money and which brands...
  30. <tuffty/>
    24,314
    5,588
    Vibra-technics
  31. westcoast a3
    319
    37
    ^^ is what I wish I had bought but will need to wait for now :/
  32. Erikn89nl
    Erikn89nl Registered User
    953
    388
    Are they comfortable to use on a daily?
  33. Avatar
    snack-media
    Advertisement
  34. <tuffty/>
    24,314
    5,588
    Depends on your definition of comfortable... fitting mounts like this changes stuff but I also have fully poly bushed suspension, camber plates, ARBs etc... the car IMO is perfectly comfortable in context but obviously it won't feel like standard...
  35. SHUk
    357
    27
    Thanks! hopefully this will eliminate my exhaust being shaken loose. Finally!!!
