Please help
kezza123 Jun 1, 2019
  1. kezza123
    kezza123 New Member
    just bought a pioneer aftermarket stereo for my A3 54 plate.
    I plugged everything in using the connects 2 harness and the unit has no power.
    I literally have no idea what I’m doing. Please can you help a damsel in distress.
  2. Avatar
    Google AdSense Advertisement
  3. leonwilliams
    leonwilliams Active Member
    681
    116
    43
    Did you see it working b4 you bought it
  4. kezza123
    kezza123 New Member
    Yeah was working before I bought it. I’m assuming the harness is the problem
  5. kezza123
    kezza123 New Member
    This is the harness
  6. leonwilliams
    681
    116
    43
    Ok halfords sell that unit take it to them and explain your issue. They will supply you with a lead that will work gonna cost about 27 quid
  7. leonwilliams
    681
    116
    43
    Power pins probably wrong way round ask about fitting and smile alot
  8. kezza123
    kezza123 New Member
    How will I know if I have to do this ignition live wiring.
  9. kezza123
    kezza123 New Member
    Does this help at all.
  10. leonwilliams
    681
    116
    43
    If you have a circuit tester ie a small screwdriver with a yellow wire on one end you could test which is live from the car side of harness. Then see which one it connects to on the stereo on the harness. Some cars have the power other way round. Mines I had to alter the power so stero was on only on with the ignition otherwise it would drain the battery. Where are you based?
  11. kezza123
    kezza123 New Member
    So my brother sorted it. We did have to do the ignition on wiring. Then he sorted out the rear speakers not working too. Once I explained what to do he did it in 10 mins.
    Thanks for your help.
  12. Avatar
  13. leonwilliams
    681
    116
    43
    Nice one glad I was of some help
