hi,
not long had my pre facelift S3 on a W plate, and ive already got the following problems.
just my luck really.
1. both headlight washers have splits in the pipes.
2. found out that i had a brand new turbo on my car, the way i found this out is that the bolts that hold the F_cking thing on came undone. and that one of the bolts haded even been done up properly.
anyway all plugged back in and bolted back together where it should be. but now i have a really high pitched scream when the turbo winds up. (almost like blowing on a bit of grass/reed), im thinking squashed pipe or split somewhere.
mate at work has vag-com so ill plug it back in tonight and update you all.
with some pics.
also need some new brake discs/pads as just noticed that mine look like polos that have been sucked on for about an hour, anyone point me in the direction of some cheap ones.
can anyone help, or even just sympathise with me, as i have spanked all my savings on this car, and as i said before its just my luck that it goes wrong and i havnt even done 500 miles in it yet.
cheers
chris
with some pics.
cheers
chris
