This was the first scan I did when I got the car, but didn't have any warning lights on dash:
Saturday,21,February,2015,19:09:29:26446
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0 (x64)
Data version: 20140822
License Plate: A4 CAB 21.02.15
Mileage: 147530km-91670mi Repair Order:
Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
63 65 67 73 75 76 77
VIN: WAUZZZ8H63K022862 Mileage: 147530km/91670miles
Address 01: Engine Labels: 059-907-401-AKE.clb
Part No: 8E0 907 401 Q
Component: 2.5l V6 TDI 0200SG 0014
Coding: 02012
Shop #: WSC 00672
VCID: 3365EBC20152268656F-4B02
Subsystem 1 - Part No: 00006059
Component: 130 106JC150_1.V79916137292
WAUZZZ8H63K022862 AUZ6Z0B0455924
5 Faults Found:
01375 - Valves for Engine Mounting; Stage 1
38-10 - Output won't Switch or Short to Plus - Intermittent
00542 - Needle lift Sensor (G80)
30-10 - Open or Short to Plus - Intermittent
18058 - Powertrain Data Bus
P1650 - 35-10 - Missing Message from Instrument Cluster - Intermittent
18043 - Powertrain Data Bus
P1635 - 35-10 - Missing Message from A/C Controller - Intermittent
01318 - Control Module for Injection Pump (J399)
49-10 - No Communications - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 1729
Coding: 04455
Shop #: WSC 00672
VCID: E5C1C59A7F06083688B-5140
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-10 - - - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 K
Component: A4 Klimaautomat 1116
Coding: 00100
Shop #: WSC 00672
VCID: 295909AAD39E6C56EC3-5140
2 Faults Found:
00716 - Air recirculation Flap Positioning Motor (V113)
41-00 - Blocked or No Voltage
00819 - High Pressure Sensor (G65)
07-10 - Signal too Low - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 00672
VCID: 3467E8DE045C21BE4F5-4B1C
No fault code found.
Address 15: Airbags Labels: 8H0-959-655-84.lbl
Part No: 8H0 959 655 B
Component: Airbag 8.4EC 1015
Coding: 0011104
Shop #: WSC 00672 785 00200
VCID: 3979D9EA733EDCD69C3-515E
1 Fault Found:
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
009 - Open or Short to Ground - MIL ON
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 01011
Shop #: WSC 00672
VCID: 3663D2D6122033AE711-4B1C
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8H0 920 950 C
Component: KOMBI+WEGFAHRS. RB4 D16
Coding: 00401
Shop #: WSC 00006
VCID: 2C57F0BEDC6C797E175-515E
Address 26: Auto Roof Labels: 8H0-959-255.lbl
Part No: 8H0 959 255
Component: VSG B6 CABRIO 6185
VCID: F3E5ABC291D2E68616F-5140
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8H0 951 178
Component: Innenraumueberw. 0411
Coding: 00001
Shop #: WSC 00000
VCID: EFEDA7B2ADFAC266F27-517C
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8H0 959 433 D
Component: Komfortgerát T3B 1210
Coding: 06795
Shop #: WSC 00672
VCID: 3561D5DA0F2638B678B-4B34
Subsystem 1 - Part No: 8H2959802
Component: Tõrsteuer.FS BRM 0001
Subsystem 2 - Part No: 8H2959801
Component: Tõrsteuer.BF BRM 0001
Subsystem 3 - Part No: 8H0959801A
Component: Tõrsteuer.HL BRM 0001
Subsystem 4 - Part No: 8H0959802A
Component: Tõrsteuer.HR BRM 0001
1 Fault Found:
01134 - Alarm Horn (H12)
29-00 - Short to Ground
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 C
Component: symphony II NP2 0151
Coding: 13001
Shop #: WSC 00272
VCID: 275D0F92C58A5A26FA7-4E98
1 Fault Found:
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
36-00 - Open Circuit
Address 63: Entry Assist,D Labels: None
Part No: 8H0 959 760 A
Component: EasyEntry F H11 X023
Coding: 00005
Shop #: WSC 00065
VCID: 3561D5DA0F2638B678B-4B1C
Address 73: Entry Assist, P Labels: None
Component: EasyEntry BF H11 X023
Coding: 00005
Shop #: WSC 00065
End ---------------------------------------------------------------------
