Play in drivers door/ dropped
Mrb.Suffolk
Searched a fair bit but didn’t find many answers.
My drivers door has dropped, I can see this as it’s hitting the wing and has left a mark. If I open the door a small amount I can feel play.
Checked the bolts on the bottom hinge in the pillar side abs they are tight. Debating a new bottom hinge, is it simple as undo the Pilar and door side bolts?
Or is there more to it?
Risky_Bisness
Yes, but the doors are heavy and hinges need to be aligned. Get a second set of hands involved
Sent from my SM-J810Y using Tapatalk
Daveyonthemove
Well-Known Member
I'm pretty sure there is a tool designed to do this.
A local VW tech had my car in for a thermostat replacement and he noticed my passenger side wouldn't close properly, so he adjusted it for me.
When I collected the car he said it had been correctly aligned, and I asked if it was a pain to do and how much extra it would cost me and he said "No charge, only took a couple of minutes as I have the correct tool".
So have a chat with a VAG specialist in your area before you tinker with the hinges, it might be a very quick job for someone with the right tool.
Mrb.Suffolk
I’ve read about essentially bending the door back into place, not sure how that sorts the play though.
Off to a VAG specialist and a body shop friend, will see what they say. Worst case I guess I replace top and bottom hinges.
