Pin Out / Wiring Diagram (Rear LED cluster)
N
Nick Sutton
Guest
Hi everyone,
I'm after a wiring diagram / pin out for the rear lights.
I have OEM LEDs clusters as standard on the S-Line, I've looked all over the web, but couldn't find anything.
Any help appreciated.
Thanks,
Nick
pajcaj
N
Nick Sutton
Guest
A few more, if you please!
Could anyone let me know the colour or location of a permanent live near the rear brake cluster?
I've found the 12v socket in the rear is only switched live (ing on), and I could do with it being permanently live..
Also, could anyone share the wiring diagram to the top brake light, located in the spoiler? Thanks!
Schizophonic
On the subject of rear LED cluster. Would I need any adapters or harness to change from the standard halogen rear clusters to the LED versions?
pajcaj
Do you have the pinout information for the MMI touchpad dial in the center console?
I will have this information but I'm not near my laptop at the moment. Hopefully get this information to you tomorrow night.
pajcaj
It may be possible to make the rear socket live without ignition on with the fuse position move. This has been described elsewhere and makes the front socket permanently live so possibly the rear also? Will need to check this of course.
GrumpyEngineer
also interested in this, i've been eyeing up the s-line led rear lights on ebay this weekend.
N
Nick Sutton
Guest
What are you trying to do, out of interest, Nick?
I'm sick of spending a fortune on the hide-away-LED lights fitted to our safety cars, so, was wanting to experiment to see if I can use the OEM LEDs in the rear clusters and top brake light with the same strobe controllers... Saves pulling the car apart to install additional LEDs basically.
So I'm thinking I should just be able to 'latch' on to the existing wiring for rear brake LEDs and perhaps the fogs two which should alternate flash rather than strobe, because these aren't LED, I don't think!..
N
Nick Sutton
Guest
Just a cheeky bump for the top rear brake light wiring diagram if I may, thanks guys?
It's a great resource you have here!
Nick
pajcaj
MMI Seems to be all can bus type connections and therefore I doubt that you can use touch pad as a USB device without knowing the electronics of the controllers.
pajcaj
Nick
Seems the only view of the additional high level brake light is shown on diagram with normal rear lights but still comes from control module J519
N
Nick Sutton
Guest
Excellent - thanks for this. Where did you get the info from if you don't mind me asking?
pajcaj
pajcaj
I have access to the repair manual for the A3 8V models
N
Nick Sutton
Guest
Handy! Could you confirm if I'm right in thinking that applying 12v to the correct bulb line will illuminate the LEDs, or is it more complicated matter?
pajcaj
I would be very careful here as you could blow the control module by back feeding a 12 volt supply. This would be very expensive to replace I would imagine! :dread:
N
Nick Sutton
Guest
Actually, if I measure what is across the wires when the LEDs are activated, and just match that, there shouldn't be a problem should there? I was wondering if I'd get any errors etc for illuminating the LEDs without the car knowing, so to speak..
Thank you again! Do you know where to get the steering wheel controls from and the wiring associated with it? I have something (joycon) that I thought turned the canbus signal into usable frequencies, but am stuck as its not functioning by tapping into the canbus H/L from the back of the MMI unit.
pajcaj
Yes should be ok and you could always put a diode in-line to stop 12 volts going back to the controller
pajcaj
No sorry I do not know, other from Audi, where you could source parts from but when I get a moment I will have a look on ETKA for OEM codes. What model do you have, i.e. S line spec etc.?
I have the base US MMI + Radio on a Premium 2.0T.
I'm thinking that I might have to get the signal directly from the steering wheel (do you know the wire information for that by chance)? I'm hoping that I don't have to go this route and can just continue to use the Canbus signal on the MMI as I was originally thinking would work.
Zahir hussain
Hi mate I was wondering if you could help me out I’ve got an rs3 sedan 2017 model and it hasn’t got wireless charging which I opted out for. Regret it now though we’ll anyway I’ve inserted the storage compartment and module antenna and got the wiring which a 6 pin plug and a 1pin aerial wire but I dnt know where to connect these to! Would appreciate it thank u
