  2. Dismiss Notice
Phenolic spacer
basil brush Feb 21, 2018
  1. basil brush
    basil brush Registered User
    620
    228
    43
    hi , I’m almost ready to fit my 034 phenolic inlet spacer !
    What have people done re the engine cover bolt brackets ?
    I want to keep the engine cover for OEM looks but I’m guessing moving the inlet out from the head also moves the engine cover bolt holes ?
    What’s the soloution please ?
    Basil :)
  2. Avatar
    snack-media
    Advertisement
  3. <tuffty/>
    <tuffty/> Badger 5 Edition...Its all about the flow... Staff Member Moderator
    24,314
    5,588
    Its been a while and I haven't got time atm to look but pretty sure I just fitted it and it didn't move enough to worry about as it moves up more than it moves away from the head..
    I may have slotted the holes on the fixings too but don't recal...
    Either way... I ran a phenolic and covers... you know this!! ;)
    basil brush and SHUk like this.
  4. SHUk
    SHUk Once Bitten Forever Smitten =]
    357
    27
    I doubled up the OEM gaskets
  5. vanilla_ice
    vanilla_ice Registered User
    796
    37
    Does it reduce IAT's? Any issues?
  6. Stuart B
    Stuart B Registered User
    3,448
    743
    It would be interesting to know whether the phelonic spacer actually increases the size of the throttle body?
  7. <tuffty/>
    24,314
    5,588
    say what?....
    A phenolic spacer is a heat insulator... limits heat exchange between the head and the inlet manifold
    Rainbird likes this.
  8. Stuart B
    3,448
    743
    I know what it is, but does this extra 1cm for each of the intake tubes make any difference to the total volume of the throttle body, or is the volume of the throttle body only calculated in the main section, as the gasket is after the injectors?
  9. superkarl
    superkarl MAN OF STEEL
    10,037
    2,677
    It has nothing to do with the throttle body
  10. <tuffty/>
    24,314
    5,588
    By throttle body I assume you mean plenum...
    Its irrelevant as air is already been metered by the MAF
  11. Stuart B
    3,448
    743
    (Sorry, I know this has digressed from the original spacer thread title)
    Okay thanks Karl and Tuffty, so the throttle body (plenum) actual size is calculated excluding the runners? I'm still unsure of the benefits of a larger throttle body unless the runners are wider as the air still has to be delivered through the rest of the circuit? Or are larger throttle bodies generally only fitted if you change to a large port head? Or is it more to do with vortex and atomisation for improved response? This is a bit beyond my basic knowledge - but still interesting.
  12. Avatar
    snack-media
    Advertisement
  13. Rainbird
    Rainbird Registered User
    468
    292
    Throttle body:
    Plenum:
    Realistically the difference in increased volume due to a phenolic spacer is negligible, don't overthink it :icon thumright:
    badger5, superkarl and Stuart B like this.
  14. <tuffty/>
    24,314
    5,588
    inlet tract volume post MAF is irrelevant in context of fuelling calculations... for the volume of the inlet tract to 'fill' air still passes by the MAF and is measured by the MAF... adding 10mm to the runner length will not affect it as the air in the inlet tract system has already been measured to fill available space be it a small std plenum or a larger aftermarket one..
    Larger plenums aid better air distribution in general... longer runners aid better torque as a rule but on turbo engines especially on boost the effect is largely subjective
  15. vanilla_ice
    796
    37
    Is there enough thread for the outer 2 nuts with a 10mm spacers plus 2 OEM gaskets?
  16. <tuffty/>
    24,314
    5,588
    Yarp
    vanilla_ice likes this.
  17. vanilla_ice
    796
    37
    Some kits seem to come with bolts for the outer 2 threads. Are the outer threads removable? Are they studs? If so, left handed threads?
  18. <tuffty/>
    24,314
    5,588
    they are studs, std threads...
  19. vanilla_ice
    796
    37
    Thank you <tuffty/>
