After coding just reset the lights by disconecting and reconnecting 12v..
Can also unplug each light.
Coding is easy. No need for expencive dealer.
Go into 09 coding search for anything with indicator, LED Blinkleuchten (must be 4on pfl)
2 will give light out error after loom install. ( code them like any other not connected light)
other 2 will be your source to work on.
First tell light % of a/b channel to be at 127% for both channels.
You might need to adress the lasttype if comming from halogen. As the lightsout errors will be triggered due to low power consumption.
Wish i could say what lightnumber your looking for, but mine is hatchback(no sportback or sedan) and lightnumbers could differ..
So first find your 4 LED Blinkleuchten in coding.. (and dont just copy mine)
Mine are on 16,17,18 and 19
You can see the lights are connected to 16 and 19. 17 and 18 are not used anymore.
[LO]_Lasttyp 16: | [VO]_38 - LED Blinkleuchten |
[LO]_BAP Bitposition 16: | 8 |
[LO]_Reserved 16: | 0 |
[LO]_Fehlerort mittleres Byte DTC-DFCC 16: | 41 |
[LO]_Lichtfunktion A 16: | 2 |
[LO]_Lichtfunktion B 16: | 0 |
[LO]_Dimmwert AB 16: | 127 |
[LO]_Lichtansteuerung HD AB 16: | [VO]_always |
[LO]_Lichtfunktion C 16: | 3 |
[LO]_Lichtfunktion D 16: | 0 |
[LO]_Dimmwert CD 16: | 0 |
[LO]_Dimming Direction CD 16: | [VO]_maximize |
[LO]_Lichtfunktion E 16: | 0 |
[LO]_Lichtfunktion F 16: | 0 |
[LO]_Dimmwert EF 16: | 0 |
[LO]_Dimming Direction EF 16: | [VO]_maximize |
[LO]_Lichtfunktion G 16: | 0 |
[LO]_Lichtfunktion H 16: | 0 |
[LO]_Dimmwert GH 16: | 0 |
[LO]_Dimming Direction GH 16: | [VO]_maximize |
[LO]_Lasttyp 17: | [VN]_0 - Keine Ansteuerung des Pins durch Konfigurator |
[LO]_BAP Bitposition 17: | 18 |
[LO]_Reserved 17: | 0 |
[LO]_Fehlerort mittleres Byte DTC-DFCC 17: | 42 |
[LO]_Lichtfunktion A 17: | 4 |
[LO]_Lichtfunktion B 17: | 0 |
[LO]_Dimmwert AB 17: | 127 |
[LO]_Lichtansteuerung HD AB 17: | [VO]_always |
[LO]_Lichtfunktion C 17: | 5 |
[LO]_Lichtfunktion D 17: | 0 |
[LO]_Dimmwert CD 17: | 0 |
[LO]_Dimming Direction CD 17: | [VO]_maximize |
[LO]_Lichtfunktion E 17: | 0 |
[LO]_Lichtfunktion F 17: | 0 |
[LO]_Dimmwert EF 17: | 0 |
[LO]_Dimming Direction EF 17: | [VO]_maximize |
[LO]_Lichtfunktion G 17: | 0 |
[LO]_Lichtfunktion H 17: | 0 |
[LO]_Dimmwert GH 17: | 0 |
[LO]_Dimming Direction GH 17: | [VO]_maximize |
[LO]_Lasttyp 18: | [VN]_0 - Keine Ansteuerung des Pins durch Konfigurator |
[LO]_BAP Bitposition 18: | 8 |
[LO]_Reserved 18: | 0 |
[LO]_Fehlerort mittleres Byte DTC-DFCC 18: | 16 |
[LO]_Lichtfunktion A 18: | 2 |
[LO]_Lichtfunktion B 18: | 0 |
[LO]_Dimmwert AB 18: | 127 |
[LO]_Lichtansteuerung HD AB 18: | [VO]_always |
[LO]_Lichtfunktion C 18: | 3 |
[LO]_Lichtfunktion D 18: | 0 |
[LO]_Dimmwert CD 18: | 0 |
[LO]_Dimming Direction CD 18: | [VO]_maximize |
[LO]_Lichtfunktion E 18: | 0 |
[LO]_Lichtfunktion F 18: | 0 |
[LO]_Dimmwert EF 18: | 0 |
[LO]_Dimming Direction EF 18: | [VO]_maximize |
[LO]_Lichtfunktion G 18: | 0 |
[LO]_Lichtfunktion H 18: | 0 |
[LO]_Dimmwert GH 18: | 0 |
[LO]_Dimming Direction GH 18: | [VO]_maximize |
[LO]_Lasttyp 19: | [VO]_38 - LED Blinkleuchten |
[LO]_BAP Bitposition 19: | 18 |
[LO]_Reserved 19: | 0 |
[LO]_Fehlerort mittleres Byte DTC-DFCC 19: | 18 |
[LO]_Lichtfunktion A 19: | 4 |
[LO]_Lichtfunktion B 19: | 0 |
[LO]_Dimmwert AB 19: | 127 |
[LO]_Lichtansteuerung HD AB 19: | [VO]_always |
[LO]_Lichtfunktion C 19: | 5 |
[LO]_Lichtfunktion D 19: | 0 |
[LO]_Dimmwert CD 19: | 0 |
[LO]_Dimming Direction CD 19: | [VO]_maximize |
[LO]_Lichtfunktion E 19: | 0 |
[LO]_Lichtfunktion F 19: | 0 |
[LO]_Dimmwert EF 19: | 0 |
[LO]_Dimming Direction EF 19: | [VO]_maximize |
[LO]_Lichtfunktion G 19: | 0 |
[LO]_Lichtfunktion H 19: | 0 |
[LO]_Dimmwert GH 19: | 0 |
If you dont want to code, connect everything exept 12v
This will disable the dynamic part and makes indicators non dynamic until you reconnect 12v after coding
