aprilia dude
any thoughts on which is the better performing car between the 3ltr tdi Quattro
And 3ltr fsi Quattro in terms of power ..mpg.. Etc
Not exaxctly a like for like comparison, but I came to my S4 from a B7 3.0TDi quattro automatic. I find a pretty reliable comparison is that in all driving modes, the S4 typically returns 10mpg less than the 3.0TDi did. So, on a motorway cruise 30-ish instead of 40-ish, and in mixed daily driving 25-ish rather than 35-ish.I get 23.5mpg mixed driving, but mostly around town with the occasional blast. I would imagine you'd get nearer double with a diesel.
I'd imagine the A4 3.0TFSI compared to the 3.0TDI would be closer.
But what about the horrible noise and horrible smell?Not exactly the same.
But I went from a fairly tuned 2.5V6 petrol to a 2.5tdi Diesel. I MUCH preferred the low down grunt of the diesel to the petrol.
Not in the UK.Is there such a thing as an A4 3.0TFSI?
Do you really not get an A4 with a detuned 3.0tfsi?Not in the UK.
Discussions about the mpg of an S-car - LOL!
When you consider that spending 2 grand on a diesel will net over 100 Bhp on almost all models then it makes sense to drive one ! I had a 300 Bhp a6 2.5 tdi quattro which felt as pokey as my current audi s4 380 Bhp bar the top end- however it still did almost 170 Mph !
I just tuned a 2.0 PPD Tdi 170 Bhp a3 quattro and after fitting a gtb2056vk turbo, a DPF delete/3" downpipe, remap tweak and a few more mods and it took 2 car lenghts on a s3 from a rolling start up to 80 Mph ! Diesel engines are not smelly and ugly or agricultural anymore and if you follow Bobby Singh project 3.0 Tdi with just a few bolt on bits it dyno-ed to 420 Bhp with a very, very clean Lambda !!! Not bad from a slow revving DERV !
Not in the UK. When I was choosing my new car, I didn't specifically set out to buy an S4. What I wanted was an A4 with a six-cylinder petrol engine. But that option hadn't been available since Audi dropped the 3.2VR6 from the range on the switch from B8 to B8.5 in 2012. So, S4 it was, and boy am I glad!Do you really not get an A4 with a detuned 3.0tfsi?
You took a ride in the new bmw m6d ? 384 Bhp stock with 40 mpg average in a car that weighs 2.5 Tonnes and with euro 6 emmision compliance so DPF, EGR, etc. The new 3.0 BiTdi from audi is also pretty potent engine with just a map goes to almost 400 Bhp. Imagine what will do with a proper gtb3576klnvr ball bearing turbo and a pair of gtd2060vzk- triturbo setup as per the Tony Banks cummins setups ! Sadly there are no larger size injectors available just yet and the CR pumps are pretty maxed up at 2200 Bars to meet stringent emissions ! What a petrol turbo engine have over a diesel is revs although that can be addressed too, there is a chap in the states that spins it's 1.9 Tdi engine at over 8000 rpm's in his mk3 home built vw golf !Very true,but if it is the supercharged 3.0 TFSI making big torque & power is only a map & pulley away.
Low down torque is plentiful also
Plus you always have to keep telling people that it isn't just a normal diesel.
I never had this issue, in fact I usually had to persuade people that it wasn't a petrol powered car.Plus you always have to keep telling people that it isn't just a normal diesel.
They definately do exist, just not in the UK it seems.3.0 TSFI on a B8 only exist as a supercharged S4
No worse than my normal Oder.But what about the horrible noise and horrible smell?
..and if I'm missing out on welly .!!
