  2. Dismiss Notice
Permanantley Live 12V Socket
cemerson Mar 30, 2014
  1. cemerson
    cemerson Registered User
    4,703
    1,237
    Perhaps, but it could also be part of the MMI system (which I suspect) as I think it turns off after 10 minutes with no ignition like the rest of the MMI. I'm sure I tested it before anyway and it did this.
  2. Avatar
    snack-media
    Advertisement
  3. Nerdy Norm
    Nerdy Norm Registered User
    70
    17
    That makes sense I guess. In which case I wonder how difficult it would be to (neatly) run a cable from the power socket at the rear of the centre console into the armrest?
    Having not got the car yet, I can't check it easily...
  4. veeeight
    veeeight I am a very pretty girl VCDS Map User
    6,842
    4,762
    If you spec the luggage and storage pack - you get an additional 12V socket in the boot - surely this would be a much safer place to leave something on charge (if safe) out of sight ?
  5. Nerdy Norm
    70
    17
    I want to put my speed camera beeper in the armrest (to use in conjunction with the MMI visual alerts described in another thread). It needs to be permanently powered, otherwise it switches off when the battery runs out after a few hours. Then I'd have to remember to switch it on again, which I probably would forget to do!
  6. veeeight
    6,842
    4,762
    Yes it is very easy to thread a cable from the rear 12V socket, to the cubby hole in the armrest.
    Because the lid doesn't actually close the cubby hole, it merely "hovers" over the top of the compartment, so it won't trap any cables.
  7. Nerdy Norm
    70
    17
    Perfect, thanks!
  8. rayss3
    rayss3 Registered User
    Is there any issue with battery drain?
  9. aurian
    aurian Registered User
    27
    Apologies for digging up an old post, but I only recently discovered this and wanted to say thanks!
    It was one of the things I missed about the 8P and I find it very useful, and even with a few odds and sods plugged in all the time (TomTom and various USB adaptors) I haven't noticed any battery drain issues :)
  10. Gazjs
    Gazjs Registered User
    481
    363
    Used this mod today to make a non essential live powered fuse for my dashcam hardwire install. Works perfectly.
  11. kkp0897
    kkp0897 Registered User
    857
    82
    A very useful post, thank you very much.
  12. Avatar
    snack-media
    Advertisement
  13. kkp0897
    857
    82
    My 8P is permanently live. While I want the Inverse to be true in my 8V (always live), do you know whether it is possible to make non-permanently live in the 8P, i.e switch off with ignition?
  14. h5djr
    h5djr Registered User Gold Supporter VCDS Map User
    9,631
    1,960
    I think you will find the information you want in the first post in this thread. It just involves moving a fuse from one position to another. Be careful what you have permanently connected to the 'always live' sockets because if you don't use your car for a while it could drain your battery.
  15. RGBARGEE
    RGBARGEE Well-Known Member
    2,705
    1,903
    Yes it works, did it on 2 8v , a 14 S3 and a 15 COD. Great mod.
  16. lakers1234
    lakers1234 Registered User
    536
    69
    This is just an absolute brilliant find!
  17. PhilsA3
    PhilsA3 Registered User
    43
    Over on the Octavia forum we discuss enviously the Audi's with their ignition switched sockets. On the Octies they are permanently live ( and no fuse moving trick). I'm in the middle of trying to hardwire my dash cam (to ignition switched fuse 48) because I can't just plug into the permanently live 12v sockets. Isn't it funny how we want the opposite of what we get.....!
  18. Zahir hussain
    Zahir hussain Registered User
    32
    Wow that’s a great find . Do you know what fuse is for the phone box. My wireless charging phone box doesn’t seem to be working.
