There's not much that's does' look at the rs4's etc
How much should a decoke be costing ? Around about figure ?
Yeah heading to bcs tomorrow for full tbe exhaust so can't push for a catch can aswell just yet lolNot expensive and usually below £200 but you need a current quote.
If you keep the and/or have it mapped etc then it may be worth considering getting rid of the problem.
I don't seem to getting the boost leak problem off my forge delete but would like to get it decoked as coming up to 70k and doubt it's ever been doneMy point about the catch can is it doesn't really deal with the coking issue but it does deal with the PCV leak problem.
That still puts carbon deposits into the engine but I'm sure Alex will be able to explain the exact workings of ithttp://www.jbsautodesigns.co.uk/product/4410/forge-motorsport-oil-catch-tank-for-vag-20-tfsi-engines
what's the difference between this and your solution then alex as this is a hell of alot smaller than your replacement cover but says it for the 265 tfsi engine in our cars
Depends if you want to stop it cokeing up or happy to keep paying to have it decoked , new pcv may not fail but the new pcv doesn't solve the cokeing problemThe later PCVs are much less prone to failure so I wouldn't bother personally.
With mine going stage 2 today (currently sat in bcs waiting room ) I think I'm going to get mine decoked over the winter when I have the cam chain and tensioner done before I get my coilovers brakes etc fittedExactly.
I think the problem is exacerbated by higher boost levels,but it's still a problem over time with stock engines.
The 8V engine gets around it with both direct,and port injectors,but unless you have either the cam cover and breather system like mine,or a port and direct injection setup(mine has this as well),you are still going to suffer coking.
I have a full set of before,and after pics on my thread,plus some taken about 6 months after a decoke,with all of the stuff back again.
I'm not all clued up with the engine Lay out etc but I no the cam chain is on the right hand side as you look at the engine from the front the tapping g from the slack/stretched chain on idle is driving me insane ! You would be amazed how many 'specialists' say o they ain't chain driven you mean u want the cambelt done ,at that point it's bye byeIt's easy enough to do,and quite quick.
If it's in bits,then it's so much easier and makes good sense.
I think it does make an obvious difference when the inlets are well coked up(!) and the engine does breathe better after.
As has been mentioned earlier, adding a PCV delete kit does not prevent the valves from coking up. There is no cheap fix for this IMHO and I doubt the OP will want to go as far as Alex has?
Yes, the system is prone to fail, make sure you fit a delete kit that's got a good rep' as seen quite a few boost leaks still come from them
Please send the links to the forums for where you did this and how it didn't sit straightoff again. Car didnt idle properly and I just really didnt like it from the word go. Never mind the fact it didnt even sit straight when fully tightened up. I have posted pics in various th
