Hi all It will lock but won't unlock I was just wondering if anyone else has had this problem and what was the remedy before I pull the door apart Thanks
Don't bother ripping the door apart until you get a replacement door lock, it's a very common fault on the A6. http://www.audi-sport.net/xf/thread...ebuild-and-repair-thread.211351/#post-2101992
Thanks for that mate its only been doing it for a cpl days sometimes it opens but most of the time it doesn't.
Hi b5nut With the passenger door not opening will that interfere with the drivers door as well not opening or is that lock on the way out as well as its not opened a cpl of times today if I lock it and re open it its OK. ..strange Thanks
Both locks have the same problem, I've had to change drivers & passenger locks on my car. However on the drivers side I had to remove the window frame, which was not as bad as I first figured.
I had the same problem after the wife tried to open the locked passenger door at the same time as I unlocked it with the remote, it wouldn't unlock for ages with the remote then one day went OK. Been OK now for 12 months.
That's strange mine just won't open and the drivers door will only open if you lock it and then open it again
Hi mate These door locks do you know what actually goes wrong with them coz they lock bit won't unlock is it the actuator that plays up or something else ??? Dave
Think it's the microswitches inside that causes the problem, I guess if you can garage the car and not need it, you may be able to get replacements and fix the unit, but I found it easier just to get used replacements from ebay, these locks were used on the A3, A4, A6, R8 and some of the other models. I got my used locks from a smashed up 2010 A3, and since replacing I've not had a problem.
Ah OK I didn't know others used the same locks that makes it a bit easier to get a pair as there's not many on eBay percificly for the c6 a6 does the c5 a6 use the same Cheers dave
No the c5 will not fit, you need cars of the same year or later (later the better) as I think they fixed this on later revision of the locks. The A3 8P will be the best option if your searching ebay.
Hi I've found 2 locks from an a3 8p but the plastic casing is blue not white do you know if that make any difference at all .the part no are the same apart from the a6 has a F in the number and the A3 has an E just want to make sure there there right ones Thanks
4E2 number was only used on the A3 & A8. Part numbers that are compatible with the A6 are 4F2837016 4F2837016B The B revision was used in the A3, A6, A8 & R8.
Thanks for that mate best I get looking again thought I'd found some but wrong ones that explains why some are dearer than others
Hi Just a quick question when I lock the doors from the switch on the drivers door and then unlock it the 2 front doors open any ideas
Yea I mean unlock lol it will unlock using the key as well it's just yet remote than it won't unlock both sides that is
Would that cause it to lock but not unlock the remote seems OK I have another remote I'll try that one just out of intrest
Right I'm confused now I tried my other key and now the drivers door opens but the passenger one still won't open ...any ideas ..I must admit I thought it strange that both doors pack up with in 24 hrs of each other ????
They are just bad locks, it can be very random on how they unlock, my drivers stopped working then started worked again and was fine for weeks, then it failed again. Since changing both my front locks I've never had a problem since. Why it's always the front locks and never the rear I've got no idea.
Door locks all done and now working the drivers side one was a complete **** with the plastic cover round it but did it in the end and even put the plastic bit back and didn't bin it lol
My passenger lock on my 2007 A6 Le Man 3.0 randomly works so needs replacing, how easy is this to do ?
Mine took around an hr a side and not to bad to do as it's passenger side you just have to fiddle to get the lock between the outer skin of the door and the window runner other than that fine
Im going to try the method based on the thread from B5NUT at the start of this post. Hopefully i can figure it out without breaking anything. My passenger side door doesn't open from the outside and i have a spare replacement i got from ebay. I just got myself a copy of the workshop repair guide and it mentions removing window frames and window regulators! I had a quick look a few weeks ago but wasnt brave enough to start stripping down the door on my newly purchased s6!
Na don't need to do that it does go past the window guide just be careful with it .you may need some of the clips that hold the door card on I did manage to save all mine
Thanks for the info, i managed to get the door card off a few weeks bag with no issues, hopefully i can get it off again without breaking any clips
