ceS3r
The last week, the hose that goes from the N75 to the Charge pipe decided to split apart, so Part Throttle would send the boost to 10 psi and then let go by itself, so, I decided to unplug the N75 so that the car would run on actuator pressure (don't know if this is the right term). Everything fine, running at 9 to 10 psi at full boost. Yesterday I "fixed" the hose, since this country is Sh#t and you can't find anything to replace it with (venezuela) and it seemed ok, boosted ok at 15psi, part throttle ok until today.... Today the car starting doing the same as before.. I checked the hose, didn't see anything obvious so I proceeded to disconnect the N75 until I figure how to fix it... But what a surprise, the car was still runing the same and now it OVERBOOSTS with the n75 unplugged, yes 18 psi with the n75 unplugged and horrible part throttle at 10 psi. The question is, what now? Is the N75 ********? Broken WG and/or Actuator?? Please this is driving me nuts.
Car is an Audi S3 8L BAM 225hp, no mods only cone filter and forge tip
