Saw these on a FL S3 in Audi stoke and wanted to know the part numbers. Assume they will fit PFL too.
Hi @creweaudiparts is that description correct with the windshield in heat insulating glass.... these are just arch / bumper flares and should only be one type???Hi,
Thanks @Sandra price vary from the 827A and 827B the only PR difference seems to be "windshield in heat insulating glass with sunshield"
Im going to order one of the 827A for tomorow and have a look at it.827B is on back if it wasnt id order that to see the difference.
I can do the 827As for £16.50 each
Wow... can you Let me know when you the one you've ordered comes in please and what it's like. I'm only over in Stoke if it's correct I'll order a pair.
These serve no purpose other than to conform with us regulations. The tires poke too far from the fender, this was their solution. Don't waste your money.
Hi,
@Robjstan got it through this morning,probably 2-3cm wide and self adhesive.Weather the one on back order is wider im not to sure but this may work for your needs.
Only RS3 though?They come on UK models too.
Only RS3 though?
TX.
Only RS3 though?
TX.
Nope, got them on the S3 too
Are they stuck on or is there a screw into the arch liner @Tom.H
Not sure off hand, its p'ing it down outside at the mo, if it stops later on I'll have a look.
That's no dedication to the quest for knowledge on these matters @Tom.H
I don't have them on my s3 saloon 2018 and I have 19in wheelsIf you have 19's from the factory you get these
I'm pretty sure these are just to conform with US regs too, to make the car body the widest bit, which is the law there. The actual mudguards you can get are much bigger I thought, and extend a lot further down the wheel arch.
Hey, do you know how to mount the front on the inside because on the inside it doesn't go straight up (the inside of the fender isn't vertical just the outside)?!Have both front and rear (they are different). See this thread for pictures and an explanation of what they’re for...
https://www.audi-sport.net/xf/threads/weird-little-mud-flap-thingies.376936/
