Parking sensors problem
Dean123
Ireland
Hi I'm wondering if anyone has had problem with parking sensors mine jus stopped working no sound and no distance in mmi I've plugged car into vcds and no fault shows I also done the ticking test and all work I've tried connections on pdc module all looks normal with everything tight hope somebody knows thanks
That could not be picking up all the fault codes, either that or some coding has changed on the car.
Could be, but I would want a better diagnostic software to confirm there are no fault codes.
What does this mean I can't find a fault code online like the thanks
if you activate the parking sensors then touch each one with your finger lightly you can feel them vibrate slightly when functioning
