Parking plus screen with only rear sensors
ChrisG.
Hi,
I'm sure I have read that it is possible to activate the parking plus screen to work even if you only have the rear sensors. I just can't find it now
I had parking plus in my A1 and now I have got an S1 with only the rear sensors. I sort of miss being able to see where the obstruction is.
Is it possible to activate this or have I just made it up?
I have located a VCDS user in my area (Sheffield) If it is possible, can somebody please help with the coding that will be required?
Chris
NotNormal
Active Member
Here you go :
Select10 (parking aid)
STG access authorization - security code 16
Access Code: 71679
STG coding -> Select function 07
Byte 2
Bit 0 - visual representation of parking assistance - activate
ChrisG.
Here you go :
Access Code: 71679
Byte 2
Thank you, I really appreciate your reply.
Chris
rasA4
Four Rings Mafia Specialist
Hi @NotNormal reviving a very old thread
@ChrisG. did you get this working?
i have a B9 and would like to do this via OBD eleven
ChrisG.
Hi,
I could never sort a convenient time to get it coded, gave up in the end tbh. Still would get it done though.
Chris
rasA4
Hi,
Chris
ok
RJ-8V
not possible on B9
rasA4
not possible on B9
so once i add the front sensors then, its possible to see the optical front and rear right?
RJ-8V
Jup
A3 8V Facelift Limousine
