Is there a way to stop the parking brake automatically going on when parking the car? I was away on holiday for 8 days and my car was seized solid with the parking brake. I was up at 4500 revs in D and R trying to get it to brake free. After about 8 or 9 times it finnaly came free. Was a lot of noise coming from the discs obviously from all the rust when driving. I work a 3 and 3 week rotation and the car has never done it before so worried why it done it there for only being parked 8 days and especially to that extend. It’s either due to the colder weather or maybe as I washed it just before I left and it had not moved since it’s last wash. Was easy enough fix in my last car as it was manual so just left it in gear and never applied handbrake.
Mine doesn’t go on automatically. Do you have hill hold turned on ? I leave that off . I turn off without applying brake . For same reasons as u state . Sent from my iPhone using Tapatalk
Yep, deactivate it with the small button on the centre console. But once turned off you will have to activate it every time after parking, or just leave it off but with the gearbox in position P. Car won’t move at all. Sent from my iPhone using Tapatalk
Should add . Happened all the time to me after cleaning if I parked up in the garage and left it for a day or two . Same thing happens on the Mrs’s up . Sent from my iPhone using Tapatalk
I should have mentioned the Hill Hold Assist activating when stopping as per another post, but that was an optional extra on the order list and not everyone specced it, I did and love it. Sent from my iPhone using Tapatalk
Yes I have this also. Very handy when in traffic. But I’ll try this and see how I get on in future. I though it automatically applied when car shut down
Since picking up mine have had two holidays and both times had no issues on first start-up regarding the brakes. One for 16 days and other for 8 days. There is a slight grab first time but it releases within milli-seconds and I always activate the parking brake when on holiday. Sent from my iPhone using Tapatalk
Mines has always been fine also. Sat for 28 days once and also released fine. That’s why I was very confused why it happened this time
Very strange, maybe a one-off or has it happened again. You must be offshore after mentioning 3-3 rota. Sent from my iPhone using Tapatalk
Happens quite often when washed and parked away for a day or more. I had to rev past 4000rpm once to get it moving. Lol To avoid this, I take car for a spin around the block to clear any water on the brakes. No issues thereafter once parked. Current - 2018 RS3 Sedan Past - 2016 RS3 SB
It’s because of the wash, even 12 hours later they are extremely viscous to release. Next time you wash it, just pull it forwards and backwards skimming the brakes to dry them off once done.
Turn off hill hold and remove seat belt before u turn off car , or after u turn off car turn just ignition on manually release parking brake and IGN turno off. should be ok
Good advice, done this on my FL S3 and have continued with my RS3, I sometimes also take it round the block for a few stop-starts, all ok after that. Sent from my iPhone using Tapatalk
