ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated ,64 ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal 15 ,64 This too?
Yes I am error free after changing abs from pla2.0 to pla3.0 Only problem that arise is default rear buzzer is nothing working anymore , all front and rear buzzer setting is all rely on the front buzzer instead I managed to flash the firmware too , now near obstacle it works Instrument speedo does not have any image - assume is normal ? Example as attachment Sent from my iPhone using Tapatalk
Yap this is in 5F so assume is all done correctly Only rear buzzer portion , is pla3.0 using only 1 buzzer instead of 2 ? Do you have any idea ? Sent from my iPhone using Tapatalk
If you have the 360degrees parking vectors in the screen try pla. Mine mmi i accadentally activated rvc low in coding.... This resulted in not working pla, pcd that stopped working , intermittendvwrking camera ..
Just check rear buzzer connection then. Or it might be defect. Switch front and rear.. Could the front and rear be on the same pitch/freq? Could the rear be muted?
Tested and check rear buzzer is not faulty, switch over and test is working fine, even wiring tested is not faulty Sent from my EVR-L29 using Tapatalk
So this means user error...(audio off, or wrong connectiin) or bad pla3.0... Got anybody naar you with a3 and pla 3.0?
hmm audio off - highly unlikely , i did another test , remove rear buzzer in D pillar , Sensors still working as normal , Remove Front sensors , all sensors stop working , with an cross image , i doubt there is an pla 3.0 near me
