Does anyone has the exact PLA coding , i am driving an A3 Pre FL - upgraded to MIB2 , everything is working fine till i fitted the PLA 3.0 1) Rear buzzer does not sound anymore whenever i engage the reverse gear 2) sometime when engage the reverse gear , PLA image show up instead of my reverse camera
i assume that car 2D image will appear when some obstacle/object is near to it , but what i hear is only buzzer but mmi did not show up any image - is that normal ?
i do have this error on my ABS Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb Part No SW: 5Q0 614 517 BJ HW: 5Q0 614 517 AG Component: ESC H62 0636 Revision: 00000000 Serial number: 61466000003170 Coding: 13F18AA22421126F897F0E0441CC29C851244891708294730221500A060802 Shop #: WSC 00046 000 00000 ASAM Dataset: EV_Brake1UDSContiMK100IPB 035019 ROD: EV_Brake1UDSContiMK100IPB_035_VW37.rod VCID: 7AB8FAA2FD26FB565D-802E 1 Fault Found: 8307 - Databus U1122 00 [009] - Implausible Message [FCAN: PLA_Status_PLA_ESP signal is invalid] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 13 Reset counter: 57 Date: 2020.09.08 Time: 13:29:59 VCDS log 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 5F-Information Electr. -- Status: Malfunction 0010 65-Tire Pressure -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 BB-Door Rear Drv -- Status: OK 0000 BC-Door Rear Pass -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CZCA) Labels:. 04E-907-309-V1.clb Part No SW: 04E 906 027 HB HW: 04E 907 309 BH Component: R4 1.4l TFS H25 4418 Revision: R7H25--- Coding: 02250032232401082000 Shop #: WSC 29277 002 1048576 ASAM Dataset: EV_ECM14TFS01104E906027HB 001006 ROD: EV_ECM14TFS01104E906027HB.rod VCID: 6B96CFE6827C52DED6-803E CAN Converter 01: No fault code found. Readiness: 0110 0001 ------------------------------------------------------------------------------- Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb Part No SW: 0CW 300 049 J HW: 0AM 927 769 E Component: GSG DQ200G2_M H05 0905 Revision: 00005006 Serial number: CU501605137744 Coding: 0014 Shop #: WSC 17734 418 534600 ASAM Dataset: EV_TCMDQ200021 001001 ROD: EV_TCMDQ200021_VW31.rod VCID: 44C4445ACF627DA677-8010 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb Part No SW: 5Q0 614 517 BJ HW: 5Q0 614 517 AG Component: ESC H62 0636 Revision: 00000000 Serial number: 61466000003170 Coding: 13F18AA22421126F897F0E0441CC29C851244891708294730221500A060802 Shop #: WSC 00046 000 00000 ASAM Dataset: EV_Brake1UDSContiMK100IPB 035019 ROD: EV_Brake1UDSContiMK100IPB_035_VW37.rod VCID: 7AB8FAA2FD26FB565D-802E 1 Fault Found: 8307 - Databus U1122 00 [009] - Implausible Message [FCAN: PLA_Status_PLA_ESP signal is invalid] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 6 Reset counter: 58 Date: 2020.09.09 Time: 16:51:14 ------------------------------------------------------------------------------- Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb Part No SW: 8V0 820 043 C HW: 8V0 820 043 C Component: AC Automat H14 0060 Revision: 20028000 Serial number: 00000000942368 Coding: 03100004110000001000000000001400 Shop #: WSC 29277 002 1048576 ASAM Dataset: EV_AirCondiFrontVaAU37X 008020 ROD: EV_AirCondiFrontVaAU37X.rod VCID: 3228128265D6C316D5-8066 Relative humidity sensor in fresh air intake duct: Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658 Component: AQ_Hum_Sensor H03 0005 Serial number: A8584C2800PAG0MUFU01 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb Part No SW: 5Q0 937 084 CL HW: 5Q0 937 084 AN Component: BCM MQBAB H H24 0175 Serial number: 01061614400337 Coding: 07041A42C24122F543804004001807A80000000000000000000000000000 Shop #: WSC 29277 002 104857 ASAM Dataset: EV_BCMMQB 015001 ROD: EV_BCMBOSCH_015.rod VCID: 0444845A8FE2BDA637-8050 Control Unit For Wiper Motor: Subsystem 1 - Part No SW: 8V2 955 119 C HW: 8V2 955 119 A Labels: 5QX-955-119-V1.CLB Component: WWS371 160503 043 0585 Serial number: 160517071625 Coding: 0A47F7 Rain Light Recognition Sensor: Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB Component: G397_RLFS H06 0004 Serial number: 61860977 Coding: 00006C Light switch: Subsystem 3 - Part No SW: 8V0 941 531 AD HW: 8V0 941 531 AD Component: E1 - LDS MQB H05 0032 Serial number: 04 03 2016 00001534 1 Fault Found: 197644 - Control Circuit for Fuel Tank Flap B1263 01 [009] - Electrical Failure Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 57 Date: 2000.00.00 Time: 00:00:00 ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb Part No SW: 5QA 919 298 D HW: 5QA 919 298 A Component: PLA 3.0 12KH07 0050 Serial number: 000308417318353 Coding: 0270061051 Shop #: WSC 00046 000 00000 ASAM Dataset: EV_EPHVA2CAU3700000 009041 ROD: EV_EPHVA2CAU3700000_009_AU37.rod VCID: 51EA7D0E0010980ECC-8004 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb Part No SW: 5Q0 959 655 AB HW: 5Q0 959 655 AB Component: AirbagVW20 015 0388 Serial number: 003MMR1T9NJQ Coding: 98CCC000000000005C54000000C800000065 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_AirbaVW20SMEVW37X 002130 ROD: EV_AirbaVW20SMEVW37X_VW48.rod VCID: 004C884A9BFAA18613-8054 Side Sensor Driver Front: Subsystem 1 - Part No SW: ----------- HW: 480 002 105 16 Component: SideSensor_Df 001 0887 Serial number: 35767000000E3430BB1W Coding: 2D2D2D Side Sensor Passenger Front: Subsystem 2 - Part No SW: ----------- HW: 480 002 105 16 Component: SideSensor_Pf 001 0887 Serial number: 3586700000082430BB1Q Coding: 2D2D2D Side Sensor Driver Rear: Subsystem 3 - Part No SW: ----------- HW: 480 401 805 16 Component: SideSensor_Dr 001 6149 Serial number: 3516502BB2076342425- Coding: 2D2D2D Side Sensor Passenger Rear: Subsystem 4 - Part No SW: ----------- HW: 480 401 805 16 Component: SideSensor_Pr 001 6149 Serial number: 3526502AF20763449052 Coding: 2D2D2D Front Sensor Driver: Subsystem 5 - Part No SW: ----------- HW: 480 401 105 16 Component: FrontSensor_D 001 6149 Serial number: 3556502992057291C365 Coding: 2D2D2D No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb Part No SW: 5Q0 953 549 E HW: 5Q0 953 549 E Component: Lenks. Modul 003 0140 Revision: -------- Serial number: 11061804680124 Coding: A018 Shop #: WSC 27213 003 1048576 ASAM Dataset: EV_SMLSKLOMQB 020002 ROD: EV_SMLSKLOMQB_019_AU37.rod VCID: 3E3036B2A18E177621-806A No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3 Part No SW: 8V0 920 871 R HW: 8V0 920 871 R Component: KOMBI H03 6423 Coding: 67AD19882A9008080101EE001000000000000000 Shop #: WSC 00046 123 12345 ASAM Dataset: EV_DashBoardVDDMQBAB 009051 ROD: EV_DashBoardVDDMQBAB_009_VW37.rod VCID: 4BD66F66E23CB2DEB6-801E 2 Faults Found: 13636608 - Control Module Incorrectly Coded U1014 00 [009] - - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 3 Reset counter: 58 Mileage: 41805 km Date: 2020.09.09 Time: 16:55:58 16776980 - Databus U1121 00 [009] - Missing Message [PLA_Status_01 keine Kommunikation] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 57 Mileage: 41805 km Date: 2020.09.09 Time: 16:55:58 ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M Component: GW MQB High 212 2246 Revision: -------- Serial number: 25051610800074 Coding: 030100043F0857005B000248180B00000001010000000000000000000000 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_GatewConti 013020 ROD: EV_GatewConti_013.rod VCID: 79BAE5AEF820F04E54-802C Alternator: Multi Function Steering Wheel Control Module: Subsystem 2 - Part No SW: 8S0 951 523 C HW: 8S0 951 523 C Component: J453 MFL H07 0002 Serial number: 20170719083548 00758 Battery Monitoring Control Module: Subsystem 3 - Part No SW: 5Q0 915 181 H HW: 5Q0 915 181 H Component: J367-BDMConti H02 1011 Serial number: 74185704001605211169 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B Component: TSG FS 020 0041 Serial number: 110516EE90176A Coding: 001E0B205C01040000001002 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003 ROD: EV_DCUDriveSideEWMAXCONT.rod VCID: 43C64746CA6C7A9E4E-8016 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb Part No SW: 5Q0 909 144 AB HW: 5Q0 909 144 AA Component: EPS_MQB_ZFLS 130 1082 Coding: 830F0000 Shop #: WSC 27213 003 104857 ASAM Dataset: EV_SteerAssisMQB 015157 ROD: EV_SteerAssisMQB_015.rod VCID: 74A4D49ADF428D2607-8020 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B Component: TSG BFS 020 0041 Serial number: 080516EE406587 Coding: 001C03205E01040000001002 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003 ROD: EV_DCUPasseSideEWMAXCONT.rod VCID: 42C84242D576739645-8016 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb Part No SW: 5Q0 907 357 HW: 6R0 907 357 A Component: LWR-ECU 005 0080 Revision: -------- Serial number: -------------- Coding: 019E000001000000 Shop #: WSC 29277 002 1048576 ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110 ROD: EV_HeadlRegulVWLWRMQB.rod VCID: 75A2E99ED438942E30-8020 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:* Redir Fail! Part No SW: 8V1 035 035 C HW: 8V1 035 035 C Component: MU-P-LND-EU 055 1326 Serial number: A698K0JS029728 Coding: 01730107FF0A000011110001000A00106F0027C601700100FE Shop #: WSC 00046 123 12345 ASAM Dataset: EV_MUHig4CGen2HBAS 001001 ROD: EV_MUHig4CGen2HBAS_VW37.rod VCID: 3228128265D6C316D5-8066 Data medium: Subsystem 1 - Part No SW: V03 959 803 BG HW: ----------- Component: ROW 2020/2021 --- 0088 Serial number: -------------------- Display unit 1 for multimedia system: Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C Component: DU High H49 0014 Serial number: AUZ8Z9H1Y07S81 Multimedia Operating Unit: Subsystem 3 - Part No SW: 8V0 919 614 BL HW: 8V0 919 614 BL Component: ControlUnit_H H85 0855 Serial number: ALJAL129061600010793 Compact Disc Database: Subsystem 4 - Part No SW: V03 959 800 EG HW: ----------- Component: Gracenote2 --- 1017 Serial number: -------------------- 2 Faults Found: 3073 - Cellular Antenna B1053 13 [009] - Open Circuit [GSM/UMTS aerial - open circuit] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 57 Mileage: 41805 km Date: 2020.09.09 Time: 16:56:40 Voltage terminal 30: 12.5 V 3084 - GSM antenna 2 B1533 13 [009] - Open Circuit Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 57 Mileage: 41805 km Date: 2020.09.09 Time: 16:56:41 Voltage terminal 30: 12.5 V ------------------------------------------------------------------------------- Address 65: Tire Pressure (J502) Labels: None Part No SW: 4M0 907 273 B HW: 4M0 907 273 B Component: RDKHUFAU736 H04 0010 Serial number: 40000000005092 ASAM Dataset: EV_RDKHUFAU736 002007 ROD: EV_RDKHUFAU736.rod VCID: 2F2E1BF676E4EEFEBA-807A No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B Component: RVC Compact H12 0231 Coding: 0273010100002003400040 Shop #: WSC 00046 123 12345 ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009 ROD: EV_CamSysRVRVCPANAMQBAB.rod VCID: 393A25AEB8A0304E14-806C No fault code found. ------------------------------------------------------------------------------- Address BB: Door Rear Drv (J388) Labels:* None Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B Component: TSG HFS 020 0041 Serial number: 300416EDT03117 Coding: 000C03204001040000001002 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_DCURearDriveMINKLO 006003 ROD: EV_DCURearDriveMAXCONT.rod VCID: 43C64746CA6C7A9E4E-8016 No fault code found. ------------------------------------------------------------------------------- Address BC: Door Rear Pass (J389) Labels:* None Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B Component: TSG HBFS 020 0041 Serial number: 300416EDT03114 Coding: 000C03204001040000001002 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_DCURearPasseMINKLO 006003 ROD: EV_DCURearPasseMAXCONT.rod VCID: 43C64746CA6C7A9E4E-8016 No fault code found.
I will make a scan of my car tommorow There should be change of coding for pla 3.0 Verzonden vanaf mijn iPhone met Tapatalk
RVC low on in mmi will give simular issues. But looking at your log i guess you did not undo all changes in all other components when upgrading to pla 3.0. When upgrading pla 2.0 to 3,0 you need to deactivate pla 2.0 and activate pla 3.0 in ABS & Cluster. All errors: ABS Byte 24 , bit 6 needs to be checked. Byte 27 bit 1 needs to be unchecked.. 09 CE (not related) Tank flap is common issue. Just replace unit. Bought mine on ali...still works after 3 jrs Instruments 17 byte 5 bit 4 unchecked byte 13 bit 1 checked. 5F (not related) installed the LTE antennas in the bumper? There is this issue. If there is still an issue please update the GW software. Upgrade to AM software..
thanks mate , before that my car does not have PLA so is not considering as upgrading , is an brand new setup , original only have reverse sensors will check on my ABS in a while 09 - as car still under agent warranty - thus will get them to change instrument 17 for byte 13 bit 1 is equal to pedestrian protection : BAP distance , YES is currently unchecked 5F LTE antennas is not in the bumper is , in the passenger glove box for GW software - is my GW compatible ? where should i download and upgrade ?
In that case: Did you change rear abs sensors or do you have ACC? The rear abs sensors need to be replaced, only not when you have ACC. Coding: ABS Byte 26 Rear left Bit 4 checked Bi-Directional Wheel Speed Sensor (Multi-Link Rear Suspension) Bit 4 & 5 checked Bi-Directional Wheel Speed Sensor (Torsion Bar Rear Suspension) Rear right Bit 6 checked Bi-Directional Wheel Speed Sensor (Multi-Link Rear Suspension) Bit 6 & 7 checked Bi-Directional Wheel Speed Sensor (Torsion Bar Rear Suspension) Byte 26 is 50 or F0 for all cars with acc and/or Pla Byte24 Bit 5 PLA3.0 Installed (this needs to be checked) Bit 6 PLA3.0 related (normally not checked,but leave bit untouched) Byte27 Bit 1 PLA2 w/ Braking Intervention Installed (this need to be unchecked) Dont worry about GW software, 1st make sure your coding is correct.
Yes I did change my both rear abs sensors , I do not have acc will check on my odis in a while for the coding As not sure why my vcds can’t really edit abs sensors
VCDS/ODIS ABS coding , i did remember clearly after i remove the old ABS sensors and fitted the new ABS sensors - the rear buzzer sound is gone , so i thought that maybe i did not completed my installation , so i continue to setup my installation next day , after completion, same issue
You already upgraded the rear sensors and put 50 into byte 26. (if no error during driving above 70 km/h then you are set, else change to F0) You coded the cars abs for pla 2.0... not 3.0. To add pla 3.0: Change byte 24 from 000000010 to 00100010 (bit 5 checked) Change byte 27 from 00001010 to 00001000 (bit 1 unchecked) Abs wil be ok now.
As i can see your car does not come with indirect tire pressure monitorng. (this is a free upgrade if you have vcds: https://www.audi-sport.net/xf/threads/enabling-tpms-for-a3-s3-8v-experimental.216661/ Also hill hold is a cheap upgrade. As yours does not come with this... And if you want: ACC is an option because you have GW high. Estimated price arround 350-400 euros depending on dealer cost of removing cp.
I do have both tpms and autohold install , both is working well Only problem for autohold on my instrument cluster does not have green logo when it is activated , as they mention my instrument cluster is too old to support / activate this green logo Sent from my iPhone using Tapatalk
ABS Fault code is clear now left with 2 issue 1) when object/obstacle is near , buzzer will sound but no image is appearing in the mmi - as you and some others mention need to upgrade the gateway ? 2) Rear Buzzer does not sound - is this something to do with the upgrade firmware of the gateway ?
Never heard of a cluster too old to support autohold. I guess 1 error in 17 is here. 2nd error should be the pla
Hi mate ,There is no fault code for all regarding to pla , later I will take a screenshot for the requested Sent from my iPhone using Tapatalk
I managed to uncheck one parallel parking , I not sure , assuming my instrument cluster not able to support the image Sent from my iPhone using Tapatalk
As i have retrofitted vc, i cannot use my coding. Coding of vc is different. I asked a friend to post his cluster coding pre and post pla. He'll be responding soon. For the cluster. Mine is a 2013 and the origional cluster supported green autohold light. As does this friends car. I need to compare his and your coding for pla and autohold. Your car should be error free (gas actuator not)
thanks mate appreciated ------------------------------------------------------------------------------ Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3 Part No SW: 8V0 920 871 R HW: 8V0 920 871 R Component: KOMBI H03 6423 Coding: 63AD19882A8008080101EE001001000000000000 Shop #: WSC 00046 000 00000 ASAM Dataset: EV_DashBoardVDDMQBAB 009051 ROD: EV_DashBoardVDDMQBAB_009_VW37.rod VCID: 4BD66F66E23CB2DEB6-801E No fault code found. for instrument cluster coding , auto hold button light is active no auto light light appearing in instrument when autohold is active no pla image when pla is activate
https://forums.ross-tech.com/index.php?threads/19949/ Lots of info here.. The FPK seems to have Byte 5 Bit 4 Active and Byte 13 Bit 0 NOT Active (maybe PLA2.0) The VDD seems to have Byte 5 Bit 4 NOT Active and Byte 13 Bit 0 Active My friend is responding on monday as he is rebuilding his car after small accident.. Coding is coming....
He retrofitted autohold... Pla image is on mib2 with pla 3.0 http://www.netech.dk/nn/Byte5.png http://www.netech.dk/nn/Byte13.png The bottem 2 are pla 3.0 and normal cluster.... Compare your byte 5 and byte 13 and try.
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,activated ,60 ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated ,60 ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated ,60 ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,not activated ,60 ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated ,60 These are on??
01730301FF0A000011110001000A00102F002BE5017001009E 5f coding (oem not touched) Search for camera and pdc /pla (camera low must be off)
Yap tank flap is another issue which will claim warranty from audi during next servicing Sent from my iPhone using Tapatalk
