  2. Dismiss Notice
P Zero Bulge
Bells May 19, 2020
  1. Bells
    Bells Registered User
    859
    781
    93
    So went out to my car this morning and noticed this big bulge on the edge of my front tyre, hadn’t noticed it before I’m sure it’ll be because of a pothole because they’ve been on for 5k miles with no issues. I’m 99% sure it’ll need to be replaced as I don’t reckon it’s safe.
    So with that in mind I’m currently looking at some part worn tyres as I’ve still got 6.2-6.5mm on the other 3 and I don’t want to mess about having different tread depths with the haldex etc. I’ve read a bit on here previously about P Zeros having a few different variants such as AO AO1 etc so when looking online I’m trying to get the same as my other 3 to satisfy my ocd, from the photos am I right in thinking I’ve got AO1’s fitted currently?
    Also any recommendations of where to source part worn tyres would be appreciated :icon thumright:
  2. Avatar
    snack-media
    Advertisement
  3. jrumball
    jrumball Registered User
    725
    372
    Audi will price match black circles ! They will supply and fit the OEM Audi spec that is correct for your car too at the price of the non Audi =)
  4. Flying Scotsman
    Flying Scotsman Registered User
    1,617
    3,151
    That alloy wheel also took a hell of a thump. I would also get that checked out and replace that tyre asap even with the pathetic skinny spare.... no motorway driving or similar speeds on that tyre.
  5. eribaMotters
    eribaMotters Registered User
    293
    128
    43
    If you'd hit a pothole hard enough to cause that damage you would remember it and something should also show on the wheel.
    I would change it asap as mentioned above and if no damage was present to the wheel keep the old tyre and get in contact with Pirelli. Some years ago the manufacturers of Mataador tyres had similar bulges appearing in a batch of tyres supplied to a leading caravan manufacturer and over the following 2 or 3 years had to replace them free of charge.
    Colin
  6. JohnM100
    JohnM100 Registered User Gold Supporter VCDS Map User
    1,598
    858
    Ouch!. Agree with others to get it changed asap and no high speed driving.
    The "A0" designation is printed on the tyre in a striped box on its own - pic attached from my 225/40/18 P zero
  7. The_Ironist
    The_Ironist Registered User
    449
    254
    Yeah definitely get swapped, could blow at any time.
    What size tire do you have as I have a 235/35 R19 P Zero AO with 5mm on for sale?
    Came off my S3 as the opposite one had a bulge and I just did all 4 tyres as my rears needed changing anyway.
    Definitely noticed the pothole that made my smaller bulge, would have thought you’d definitely notice whatever caused that. It does look like a pothole as it’s pressed the tyre into the alloy and left rubber on it like mine did.
  8. steverobertsbbc
    steverobertsbbc Registered User
    489
    218
    43
    Just checking that you have noticed that the wheel looks badly damaged at the same point?
  9. The_Ironist
    449
    254
    It may just be rubber where the tyre has been squished into it but worth confirming.
  10. steverobertsbbc
    489
    218
    43
    Ah, yes - you're probably right! Lucky escape if so, must have been a hell of a pothole!
  11. Bells
    859
    781
    93
    Thanks for all the replies I’ve looked at the alloy and seems it’s all fine, there is a mark where the rubber seems to have rubbed against the alloy but other than that I’m hoping it’s ok but will obviously get the garage to check it out properly when the tyre gets replaced.
    That’s strange I have the code AO11833 printed on the tyre but nothing with a striped box on its own like yours?
  12. Avatar
    snack-media
    Advertisement
  13. rafletcher
    rafletcher Registered User
    388
    101
    43
    I kerbed a tyre, but not the wheel, and got a bulge like that. Only noticed the bulge when filling up a couple of weeks, and 300 motorway speed miles later!
  14. jassyo06
    jassyo06 T-Cut King !
    19,670
    40,255
    You have 225/40/18 Pzero sc ao1 fitted Screenshot_20200522-111702_Chrome.jpg
    Bells likes this.
  15. S32B
    S32B Registered User
    6,583
    7,691
    Stay away from it mate, I'd be calling the Audi assist out and get them to put the spare on, once off tell them to take all the air out of the damaged tyre. As for sourcing one, just Goole part worn tyres in your area. Take a good look at it first though, a lot of part worns have been repaired.
    Bells likes this.
  16. JohnM100
    1,598
    858
    I knew Pirelli had a rep for weak sidewalls 20 years ago but thought they had fixed that. Doesn’t seem as though they have done so totally.
    I know the wear thread in the RS3 forum but that’s separate.
    Bells likes this.
  17. jassyo06
    19,670
    40,255
    Tyre preference is as subjective as the brand of car of car you prefer these days,l got only 11k miles out of the factory fitted P zeros,this time around l got 16k miles....low wear rate was due to the hot summer we had 2 years ago so l was told,getting another set of P zeros fitted next week and l wont be buying another set as l wont be the owner of it when there due to be renewed
    Bells likes this.
  18. Bells
    859
    781
    93
    Quick update, I’ve got a part worn P Zero tyre coming on Tuesday that’s got 6.3mm of tread to match the other 3 perfectly and it only cost me £60. Must say a 19 inch tyre was hard to find that was part worn as there’s not many about, most available have had repairs done on them.
    Cars not going anywhere currently but I’ve got a garage less than 2 minutes down the road so I’ll just baby the car down there one morning to get it fitted.
    I’ve also retraced my last route and found the offending pothole so a claim will be going into the Council to cover my costs, so I’ll have to wait and see how that goes.
  19. Bells
    859
    781
    93
    Yeah ideally I’d want to put Michelin Pilot Super Sports on but can’t justify changing all 4 tyres currently seeing as they’ve got so much tread depth. I don’t rate the P Zeros really but have to say they’ve not done bad on wear, I don’t baby the car and they’ve only used about 2mm of tread in 5k miles which I think is decent.
  20. eribaMotters
    293
    128
    43
    That pot hole you mention. If it has a spray can ring around it marked for repair then you may be in luck. There should be a date record of inspection on it at the Parks and Highways dept of the council, with it scheduled for repair. If no mark then they could reasonably say they were unaware of it.
    Colin
  21. JohnM100
    1,598
    858
    Also worth checking FixMyStreet as it may have been reported but they haven’t got around to inspecting it or deemed it not requiring repair.
