Osram bulbs
Dobby
a garage fitted my new osram bulbs as one of my original ones blew, do these look fitted correctly or are the bulbs complete rubbish?
orginal v osram
Dobby
Bottom pic looks as though one is a different colour.
sorry yeh thats the original bulbs ( just before left one blew) but its only one i have to compare
jassyo06
T-Cut King !
Nothing wrong with your new bulbs or there fitting, one is about 3400k yellow light the other about 4500k the white light
M
MrFlibble
Guest
The ones in 1368 look better.
Osram bulbs are fine. Audi use Philips at the factory, but Osram are the OE supplier for various other marques.
Buying discharge lamps from a name brand (Philips, Osram, GE or Toshiba) is recommended (note that the main suppliers of D3S bulbs are Philips and Osram).
Be wary of buying cheap or off-brands; the quality is often very poor. I tried a few sets on an old car (at £25 a pair, compared to £60 each, it was worth a short), and they were invariably rubbish - the longest I got was 12 months, most died within about 6 months, and they were noticeably dimmer than a genuine set of Philips bulbs.
Finally, be careful if you are buying these yourself. Fakes are rampant. This is such a problem, that manufacturers give detailed instructions on how to spot counterfeits.
Dobby
the ones in 1368 are a whiter light but are very dim compared to the other picture showing the originals. also the light isnt as even spread out, on the left side you see kind of a beam and when going over bumps etc it shakes. complete **** imo and ill be chucking them at the next opportunity
jassyo06
T-Cut King !
I would look at a 5k hid bulb by Phillips never been a fan of osram bulbs full stop
Autobulbs.co.uk and hids4u are the best sites to find GENUINE quality hid bulbs for your car, you can even call them for advice...
