here is the scan, the errors on the radio are because i've detached the glove box for doing the cabling, and my ipod conection is undone
the error on the parking assist is because i'm missing one buzzer
Wednesday,10,October,2018,12:28:39:54500
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WAUZZZ8P7CA066754 License Plate:
Chassis Type: 8P-AU35 (7N0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 22 25 37 42 44 46 4C 52 55
56 77
VIN: WAUZZZ8P7CA066754 Mileage: 68440km-42526miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (CDL) Labels:. 06F-907-115-CDL.clb
Part No SW: 8P0 907 115 AQ HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH20--- Serial number: AUX7Z0K9FN50NT
Coding: 0103000C1C0F0160
Shop #: WSC 00191 264 15243
VCID: 010808A058DDEE4E85-8054
No fault code found.
Readiness: 0000 0001
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 013 S HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2739
Revision: 05351113 Serial number: 00001109161185
Coding: 0000020
Shop #: WSC 06314 000 00000
VCID: 21486820F81D0E4EA5-8074
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 1442801249280000281201E9921D00413F0400
Shop #: WSC 10940 002 1048576
VCID: 7BF47A48FA31849EDF-802E
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8U0 820 043 F HW: 8U0 820 043 F
Component: E87 Klimavoll 0210
Revision: 00H05000 Serial number: 8U0820043F
Shop #: WSC 00000 000 00000
VCID: 3466917457EF8BE65E-8060
1 Fault Found:
00457 - Control Module for Network (J519)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 27
Mileage: 68120 km
Time Indication: 0
Date: 2018.07.04
Time: 05:29:36
Freeze Frame:
ON
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 N HW: 8P0 907 063 N
Component: BCM PQ35 M 110 0653
Revision: 00110 AF
Coding: 4E000A2FA807F200207241E00100094C427E8DAA206DD928E40008840040
Shop #: WSC 61503 615 104880
VCID: 3F8CCE58AEA958BEB3-806A
Subsystem 1 - Part No SW: 8P1 955 119 F HW: 8P1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H11 0050
Coding: 00DD13
Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 D Labels: 8K0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 024B2D
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumuebe H04 0020
Subsystem 4 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Subsystem 5 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X2.clb
Part No SW: 8P0 919 475 Q HW: 8P0 919 475 N
Component: PARKHILFE 8K H01 0150
Revision: 11001001 Serial number: 12531736100770
Coding: 100109
Shop #: WSC 12345 123 12345
VCID: 4C96E994EF1FF32626-8018
1 Fault Found:
01543 - Parking Aid Warning Chime (H15)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 41
Mileage: 68440 km
Time Indication: 0
Date: 2018.10.08
Time: 11:39:11
Freeze Frame:
Temperature: 18.0∞C
Address 14: Susp. Elect. Labels: 8P0-907-376.lbl
Part No SW: 8P0 907 376 A HW: 8P0 907 376 A
Component: J250 Raddaempfung 0060
Revision: --H04--- Serial number: 190DPH 1179305
Coding: 0000132
VCID: 3978A040708D768E8D-806C
Address 15: Airbags (J234) Labels:| 8P0-959-655-10.clb
Part No SW: 8P0 959 655 S HW: 8P0 959 655 S
Component: Airbag AU1042 H09 0250
Revision: -------- Serial number: 003JU0044CK6
Coding: 303142413039303030344A55304C38503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 52AAF7EC053BA5D66C-8006
Crash sensor for side airbag: driver side:
Serial number: 34928RB40000654048BK
Crash sensor for side airbag: front passenger side:
Serial number: 35028RB4000066119939
Crash sensor for side airbag: rear: driver side:
Serial number: 35128RB4000065404C06
Crash sensor for side airbag: rear: passenger side:
Serial number: 35228RB40000661199BJ
Crash sensor for front airbag: driver side:
Serial number: 35547RB4000066649C2P
Crash sensor for front airbag: front passenger side:
Serial number: 35647RB4000066649B1O
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0014142
VCID: 4682DBBC31730976F0-8012
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H03 0040
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 932 P HW: 8P0 920 932 P
Component: KOMBIINSTR. VDO H02 0150
Revision: D0H02002 Serial number: 2249K002001124
Coding: 0337128
VCID: 4188C8A0185D2E4EC5-8014
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 H HW: 1K0 907 951
Component: J533 Gateway H42 1620
Revision: H42 Serial number: 210911F2002438
Coding: 350100
Shop #: WSC 06314 123 12345
VCID: 3560AC709C9592EE69-8060
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BR 907 554 C HW: 0BR 907 554 C
Component: Haldex 4Motion 3018
Coding: 0000005
VCID: 4580DCB00C75026EF9-8010
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H02002 Serial number: AUX7Z0K9FN50NT
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
Component: RNS-E PU EU H07 0220
Revision: 0000013S Serial number: AUZBZ7ND200719
Coding: 0229757
1 Fault Found:
00857 - CD Changer Unit (R41)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 41
Mileage: 68440 km
Time Indication: 0
Date: 2018.10.08
Time: 11:42:02
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 Q HW: 8P0 959 801 Q
Component: Tuer-SG H04 0101
Coding: 0000020
VCID: 4998D080206DE60E1D-801C
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 234 3201
Revision: 00H20000
Shop #: WSC 02069 000 90108
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 8P0 959 802 Q HW: 8P0 959 802 Q
Coding: 0000020
VCID: 4A9AEF8C256BED1614-801E
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 M
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000014
VCID: 4486C1B4074F3B66EE-8010
Address 56: Radio
Cannot be reached
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P1 862 335 A HW: 8P1 862 335
Component: FSE_256x BT H44 0660
Revision: 00000000 Serial number: 00000005447037
Coding: 0011455
VCID: 3560AC705C9592EE69-8060
End-------------------------(Elapsed Time: 02:06)--------------------------
