  2. Dismiss Notice
Optical Parking System Mod Installed
NHN Aug 6, 2010
  1. idmax
    idmax Member
    13
    Just managed to get OPS working on my A4 B7. Details to follow
  2. Avatar
    snack-media
    Advertisement
  3. rum4mo
    rum4mo Well-Known Member
    1,991
    479
    Okay, seeing as I did not see this sub section, I started a thread in the A4 B8 main section, and I also have retro fitted front PDS and OPS to a car that originally only had rear PDS, used Audi parts and VW parts where necessary and a couple of Kufatec cables.
  4. fernando young
    fernando young Active Member Team Daytona Audi RS3
    304
    may i bump this?
    i've installed my 7x2 parking sensor kit
    4 sensors in the back
    4 sensors in the front
    latest revision of the 7x2 module 8P0919475Q
    pdc button installed
    the cable wired to the terminal 51 on the white plug of the BCM
    the 2 CAN cables wired to the 6 and 16 on the gateway
    everything is coded, accepted and gets no fault code
    my RNSE ends in 193G
    the PDC module is coded for optical parking sensors, automatic transmission and audi s3 8p1
    and the radio is coded with '2' for the optical monitoring
    everything seems to be okay, but i still dont get image on my RNSE screen, i only get the beeping, and its getting frustrating
    i need help
  5. NHN
    30,821
    2,094
    Reset the rns & also it sometimes takes a while for the setting to take hold, mine originally took hours to start working, bizarrely.
  6. fernando young
    304
    i'm a little worried, because its been days, my car has been disassembled for a week now and i'm still wondering whats wrong but i cant find anything.
    i'm missing one buzzer because it hasnt arrived yet (ordered two and the ******* only sent one) but i highly doubt it is not working because of the buzzer.
    do you suggest me to put everything back together and just wait till it works?
    should i restart the rnse pressing the two buttons on the ends? or with the cold restart on vcds?
  7. fernando young
    304
    @NHN may i send you a PM?
  8. NHN
    30,821
    2,094
    Keep it on the thread please.
  9. fernando young
    304
    my car is 2012, and the pdc button for that year should be the full button bar, not the individual button
    i bought the individual button unfortunately, but modified the trim to make it fit, and the cabling was fit without any issues, i dont think that is causing the issue, right?, because it still enables the parking when i click it, and the light flashes, so...
    would that be an issue?
  10. NHN
    30,821
    2,094
    What firmware version is the rns?
    Did you enable 10 in can gateway
  11. fernando young
    304
    10 is the steering assist module, right?
    i did enable that one.
    the firmware on my rnse, i dont really know, will give it a scan right now
  12. Avatar
    snack-media
    Advertisement
  13. NHN
    30,821
    2,094
    No, when you fit the newer pdc, the parking 76 now becomes 10, make sure you disable 1 & enable the other.
  14. fernando young
    304
    address 10 is enabled, didnt check about addres 79 but it might be dissabled, since i didnt have any parking sensors before
    PDC Module
    part numer 8p0919475Q
    componen parkhilfe 8k h01 0150
    coding 100109
    RNS
    part number 8p0035193G
    componen rns-e pu eu h07 0220
    coding 0229757
  15. NHN
    30,821
    2,094
    Show a complete scan of the car.
  16. fernando young
    304
    here is the scan, the errors on the radio are because i've detached the glove box for doing the cabling, and my ipod conection is undone
    the error on the parking assist is because i'm missing one buzzer
    Wednesday,10,October,2018,12:28:39:54500
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 17.8.0.1 (x64)
    Data version: 20170721 DS276.2
    www.Ross-Tech.com
    VIN: WAUZZZ8P7CA066754 License Plate:
    Chassis Type: 8P-AU35 (7N0)
    Scan: 01 02 03 08 09 10 14 15 16 17 19 22 25 37 42 44 46 4C 52 55
    56 77
    VIN: WAUZZZ8P7CA066754 Mileage: 68440km-42526miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: Malfunction 0010
    14-Susp. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    4C-Tire Pressure II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    77-Telephone -- Status: OK 0000
    Address 01: Engine (CDL) Labels:. 06F-907-115-CDL.clb
    Part No SW: 8P0 907 115 AQ HW: 8P0 907 115 B
    Component: 2.0l R4/4V TFSI 0010
    Revision: 5BH20--- Serial number: AUX7Z0K9FN50NT
    Coding: 0103000C1C0F0160
    Shop #: WSC 00191 264 15243
    VCID: 010808A058DDEE4E85-8054
    No fault code found.
    Readiness: 0000 0001
    Address 02: Auto Trans Labels: 02E-927-770.clb
    Part No SW: 02E 300 013 S HW: 02E 927 770 AL
    Component: GSG DSG AG6 511 2739
    Revision: 05351113 Serial number: 00001109161185
    Coding: 0000020
    Shop #: WSC 06314 000 00000
    VCID: 21486820F81D0E4EA5-8074
    Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
    Component: ESP MK60EC1 H31 0121
    Revision: 00H31001
    Coding: 1442801249280000281201E9921D00413F0400
    Shop #: WSC 10940 002 1048576
    VCID: 7BF47A48FA31849EDF-802E
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8U0 820 043 F HW: 8U0 820 043 F
    Component: E87 Klimavoll 0210
    Revision: 00H05000 Serial number: 8U0820043F
    Shop #: WSC 00000 000 00000
    VCID: 3466917457EF8BE65E-8060
    1 Fault Found:
    00457 - Control Module for Network (J519)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 27
    Mileage: 68120 km
    Time Indication: 0
    Date: 2018.07.04
    Time: 05:29:36
    Freeze Frame:
    ON
    Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
    Part No SW: 8P0 907 063 N HW: 8P0 907 063 N
    Component: BCM PQ35 M 110 0653
    Revision: 00110 AF
    Coding: 4E000A2FA807F200207241E00100094C427E8DAA206DD928E40008840040
    Shop #: WSC 61503 615 104880
    VCID: 3F8CCE58AEA958BEB3-806A
    Subsystem 1 - Part No SW: 8P1 955 119 F HW: 8P1 955 119 F Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H11 0050
    Coding: 00DD13
    Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 D Labels: 8K0-955-559.CLB
    Component: REGENLICHTSEN H04 0003
    Coding: 024B2D
    Subsystem 3 - Part No: 8P0 951 177
    Component: Innenraumuebe H04 0020
    Subsystem 4 - Part No: 1K8 951 605 B
    Component: LIN BACKUP HO H11 9005
    Subsystem 5 - Part No: 1K0 907 719 C
    Component: Neigungssenso 005 0003
    Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X2.clb
    Part No SW: 8P0 919 475 Q HW: 8P0 919 475 N
    Component: PARKHILFE 8K H01 0150
    Revision: 11001001 Serial number: 12531736100770
    Coding: 100109
    Shop #: WSC 12345 123 12345
    VCID: 4C96E994EF1FF32626-8018
    1 Fault Found:
    01543 - Parking Aid Warning Chime (H15)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 41
    Mileage: 68440 km
    Time Indication: 0
    Date: 2018.10.08
    Time: 11:39:11
    Freeze Frame:
    Temperature: 18.0∞C
    Address 14: Susp. Elect. Labels: 8P0-907-376.lbl
    Part No SW: 8P0 907 376 A HW: 8P0 907 376 A
    Component: J250 Raddaempfung 0060
    Revision: --H04--- Serial number: 190DPH 1179305
    Coding: 0000132
    VCID: 3978A040708D768E8D-806C
    Address 15: Airbags (J234) Labels:| 8P0-959-655-10.clb
    Part No SW: 8P0 959 655 S HW: 8P0 959 655 S
    Component: Airbag AU1042 H09 0250
    Revision: -------- Serial number: 003JU0044CK6
    Coding: 303142413039303030344A55304C38503053
    ASAM Dataset: EV_Airba10AURB4 001001
    ROD: EV_Airba10AURB4.rod
    VCID: 52AAF7EC053BA5D66C-8006
    Crash sensor for side airbag: driver side:
    Serial number: 34928RB40000654048BK
    Crash sensor for side airbag: front passenger side:
    Serial number: 35028RB4000066119939
    Crash sensor for side airbag: rear: driver side:
    Serial number: 35128RB4000065404C06
    Crash sensor for side airbag: rear: passenger side:
    Serial number: 35228RB40000661199BJ
    Crash sensor for front airbag: driver side:
    Serial number: 35547RB4000066649C2P
    Crash sensor for front airbag: front passenger side:
    Serial number: 35647RB4000066649B1O
    Address 16: Steering wheel Labels: 8P0-953-549.lbl
    Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
    Component: J0527 H37 0070
    Coding: 0014142
    VCID: 4682DBBC31730976F0-8012
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 H03 0040
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 932 P HW: 8P0 920 932 P
    Component: KOMBIINSTR. VDO H02 0150
    Revision: D0H02002 Serial number: 2249K002001124
    Coding: 0337128
    VCID: 4188C8A0185D2E4EC5-8014
    Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 H HW: 1K0 907 951
    Component: J533 Gateway H42 1620
    Revision: H42 Serial number: 210911F2002438
    Coding: 350100
    Shop #: WSC 06314 123 12345
    VCID: 3560AC709C9592EE69-8060
    Address 22: AWD Labels: 0AY-907-554-V1.clb
    Part No SW: 0BR 907 554 C HW: 0BR 907 554 C
    Component: Haldex 4Motion 3018
    Coding: 0000005
    VCID: 4580DCB00C75026EF9-8010
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H02002 Serial number: AUX7Z0K9FN50NT
    Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
    Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
    Component: RNS-E PU EU H07 0220
    Revision: 0000013S Serial number: AUZBZ7ND200719
    Coding: 0229757
    1 Fault Found:
    00857 - CD Changer Unit (R41)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 41
    Mileage: 68440 km
    Time Indication: 0
    Date: 2018.10.08
    Time: 11:42:02
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
    Part No SW: 8P0 959 801 Q HW: 8P0 959 801 Q
    Component: Tuer-SG H04 0101
    Coding: 0000020
    VCID: 4998D080206DE60E1D-801C
    Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
    Part No: 1K0 909 144 M
    Component: EPS_ZFLS Kl. 234 3201
    Revision: 00H20000
    Shop #: WSC 02069 000 90108
    Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
    Part No SW: 8P0 959 802 Q HW: 8P0 959 802 Q
    Coding: 0000020
    VCID: 4A9AEF8C256BED1614-801E
    Address 55: Headlight Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 M
    Component: Dynamische LWR H01 0010
    Revision: 00000001 Serial number:
    Coding: 0000014
    VCID: 4486C1B4074F3B66EE-8010
    Address 56: Radio
    Cannot be reached
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P1 862 335 A HW: 8P1 862 335
    Component: FSE_256x BT H44 0660
    Revision: 00000000 Serial number: 00000005447037
    Coding: 0011455
    VCID: 3560AC705C9592EE69-8060
    End-------------------------(Elapsed Time: 02:06)--------------------------
  17. NHN
    30,821
    2,094
    Fit the missing buzzer then retest.
    You could try temp wiring the single buzzer into both inputs see if it helps although I dont know the outcome, so at your own risk.
  18. fernando young
    304
    haha i think i rather wait, it should come this week.
    but still, dont you think it is strange? everything should be working
