ONLY driver door is unlocking
wrightyrx7
Manchester
Hi all,
I have a 59 plate A3 sportback.
Over the past year all the door except the drivers door have stopped unlocking. This problem was intermittent to start with. Now all the other doors seem dead. The button inside does not unlock them either. The only way to open them is to use the inside handle.
Problem is, I need to put the child locks on. And if i do that, there will be no way to open the rear doors as the option to open it from the inside will also be gone.
I have give it a scan with VCDS and the results are below. And help would be great.
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-021-BLS.clb
Part No SW: 03G 906 056 S HW: 03G 906 021 AB
Component: R4 1,9L EDC 000SG 2917
Revision: --H09--- Serial number: AUX7Z0HDFN30RP
Coding: 0000071
Shop #: WSC 66565 257 00032
VCID: 37773F73469DB2F756-8062
3 Faults Found:
005661 - Glowplug for Cylinder 4 (Q13)
P161D - 000 - Open Circuit
Freeze Frame:
Fault Status: 01110000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 183985 km
Time Indication: 0
Date: 2019.11.29
Time: 17:30:30
Freeze Frame:
RPM: 966 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.63 V
Bin. Bits: 00000100
Temperature: 13.5°C
Bin. Bits: 10110000
005660 - Glowplug for Cylinder 3 (Q12)
P161C - 000 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 255
Mileage: 183985 km
Time Indication: 0
Date: 2019.11.29
Time: 17:31:37
Freeze Frame:
RPM: 1680 /min
Speed: 11.0 km/h
Load: 63.9 %
Voltage: 13.83 V
Bin. Bits: 00000100
Temperature: 16.2°C
Bin. Bits: 10110000
005488 - Engine Start Blocked by Immobilizer
P1570 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 184002 km
Time Indication: 0
Date: 2019.11.30
Time: 00:04:07
Freeze Frame:
RPM: 1008 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.63 V
Bin. Bits: 00000100
Bin. Bits: 00000000
(no units): 33.0
Readiness: 0 0 0 0 0
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K08B28000D
Coding: E9807F06000202002103
Shop #: WSC 06314 000 00000
1 Fault Found:
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 2
Reset counter: 163
Mileage: 184090 km
Time Indication: 0
Date: 2019.12.07
Time: 04:24:02
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Component: Tuer-SG H03 0060
Coding: 0000692
VCID: 448D58BF074BE96FC3-8010
1 Fault Found:
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
008 - Implausible Signal
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000144
Shop #: WSC 06314 000 1012544
VCID: 418351AB1859FC47E8-8014
1 Fault Found:
00930 - Locking Module for Central Locking; Rear Left (F222)
008 - Implausible Signal - Intermittent
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000144
VCID: 42815EA71D5FE75FF1-8016
1 Fault Found:
00931 - Locking Module for Central Locking; Rear Right (F223)
End-------------------------(Elapsed Time: 01:48)--------------------------
Open the front doors & check for broken wires in the door hinge rubbers.
I found on mine this was caused by a broken wire. Mine was a 10 plate so I don’t know how similar they are but there’s a data cable (purple and white) that allows the doors to talk to the convinience unit under the dash.
The way it’s cabled is weird so bare with me:
Drivers side - CU>Drivers door>rear door
Same with passenger side so worth checking for a broken cable in all 4 doors but I’d start with the front doors
Facelift cars have a bus wire connecting fronts to rears, older had individual bus wires to each door, however if the driver door has broken wires it can cause issues all round.
This is exactly what I faced - only the drivers door wire was broken but effecting all doors.
Great stuff, thank you all for your suggestions.
I will get all the above checked out this weekend and let you know how I get on.
Thanks again.
