One touch windows gone?
Swervedriver
After a recent flat battery, I've lost the one touch control on my windows. S3 8l by the way. Any idea fellas? All help much appreciated.
Regards
Craig.
VAG-Slag
need to reset them Craig... With the windows all the way up, hold both buttons up for three seconds
Nilz
Defo worth the wait :)
Drop the windows down, then all the way up whilst holding the switch, once they are at the top, let go of the switches, then do it to put them up again and they should make a quiet click noise, this will reset them for you.
Alternately you can disconnect the battery for about 20 mins and cycle the windows all the way up and down. This should also fix the problem, as I had a similar issue and a battery disconnect rectified this fault.
VAG-Slag
Sorry, I know you're only trying to help, but this is a ridiculous suggestion seeing as A) the correct method only take 3 seconds and B) once you've disconnected the battery you'll have to reset the windows via the method mentioned earlier anyway (which takes 3 seconds)
No problem mate, but my windows weren't fully cycling (drivers side window wouldn't go down all the way) and the above fixed that along with the one touch window setting.
Just my experience...
VAG-Slag
Ok, fair enough... I'd say there was something else going on there then but if it works it works!
jojo
Looking for Boost!
Staff member
Moderator
This IS the correct way to reset your electric windows after you disconnect your car battery. The one touch can be reactivated with just pulling up on the window switches for 3 secs with the window full closed. But you are suppose to open them all the way down and back up for the motors to learn where the limit of the open and closed positions of the window.
