  2. Dismiss Notice
  1. Mitchmcd
    Mitchmcd Registered User
    12
    Hi I had my s4 in at maindealers and had the S tronic serviced but what is the filterelem part# AO6E115562C and also changed my engine oil to 0w30 I’m wondering if this is too thin it’s meeting vw 504 and 507 I thought it would be 5w30 cars a 2011 s4 any help would be great
  2. Avatar
    snack-media
    Advertisement
  3. MuPPeT_ON_TouR
    MuPPeT_ON_TouR Well-Known Member Silver Supporter
    490
    301
    Is a bit strange the 0w30 oil. I always thought it was 5w30 As well.
    There are technically 2 filters for the gearbox. One is an internal strainer that involves taking off the sump to change it. The other is an inline filter, this is the one normally changed for a gearbox service, the internal strainer is not standard for an Audi service.
  4. Gazwould
    Gazwould Registered User
    7,531
    3,045
    504 is high quality and available as 0W and 5W , tons of detergents and dispersants as it's a LongLife oil and even should contain some group 5 ester as like the top Fuchs , Millers etc , ester racing oils .
    Just regularly check if there's a consumption issue as some experience especially with a 0W .
  5. Carlos85
    Carlos85 Registered User
    310
    296
    I found that mine used a bit of oil on 5W30 when it was tuned so I went to 5W40 and it hasn't used a drop since the service a couple of thousand miles ago so it does seem a bit strange to have gone for 0W30.
  6. Gazwould
    7,531
    3,045
    0W30 is thinner at the high temp end than 5W30 !
    Expensive machinery , use a 5W40 racing ester marketed oil .
  7. Mitchmcd
    12
    Thanks for the reply’s guys I’ll keep my eye on the oil level sounded ok on start up and seems to be running fine I’ve got 10litres of Castrol edge 5w30 in my garage so might change to that
  8. Dippy
    Dippy Registered User
    1,981
    1,339
    Don't you mean at the low temp (starting) end?
  9. Gazwould
    7,531
    3,045
    For sure it's thinner at low temps .
    But that's why I love oil so much , the misconceptions...
    Widening the viscosity range is more difficult to achieve , 0W50 is as wide as it gets.
    So to offset this , that particular 0W30 will be thinner at high temp than a 5W30 of the same 504.00 spec , hense why it may get consumed .
  10. rum4mo
    rum4mo Registered User
    2,192
    557
    My 2011 S4 got Shell 0W30 in it once at a main dealer, but I've always used 5W30 when I service it.
    Edit:- that part number you quoted is the current number for the oil filter element - which is just a MANN HU 7029 inside VW Group packaging.
  11. scotty76
    scotty76 Registered User
    3,829
    2,830
    Can confirm dealers put 0W30 in my S4 at the first service. Since then it mostly seems to have been 5W30.
  12. Avatar
    snack-media
    Advertisement
  13. Mitchmcd
    12
    Thanks for that 0w30 must be the spec they use at main dealers I thought it would have been 5w30 but I’ll keep my eye on it and change to 5w30
