oil is changed every 10,000 without fail, its the sensor warning, nout wrong with pressure or levels, i reckon its come loose in the pan or a dodgy wire, just wanted some clarifacation it was ok to use as normal ?
i certainly wouldnt run it with any oil light... even if the leval is ok you need to scan for faults before you go any further. atleast this will help determin if its a failed sensor or somethink further afield that will cause major failure...
Well that was an easy fix, never worry if this error occurs it was simply the sensor becoming slightly dislodged in the oil pan, pushed back on, 6.2 litres of castrol edge later job done !
