D
Deleted member 138002
Guest
Evening all,
I've seen a few forum posts mentioning issues with the 2.0TFSI oil pump. Is there an intrinsic design issue with them, and if so, how can I try to mitigate it on mine? I saw a link to this kit which claims to remove the (allegdly) problematic sprung loaded balance shaft sproclet, and replace it with a solid sprocket:
Will this help future proof the oil pump? Engine is currently on 122k, and I plan on changing the cam chain + tensioner, and fitting the revised oil pickup pipe, so am tempted to have the mechanic do this at the same time if it will help, unless there any other suggestions? I've seen people fit the 1.8T oil pump, but would rather try and improve the existing one if possible. I'm not sure if its relevant, but my A4 is the Special Edition and has the BUL engine in it which allegedly had some improvements, not sure if the oil pump was addressed too as I know the cam design was changed to reduce wear on the follower for the HPFP.
Any help and insight is much appreciated as I'm still getting to know these engines, and plan to keep the car for a long time to come.
Best Regards,
Ben
Best Regards,
Ben
