Oil pressure light is on & three deadly beeps!
S3KO4
Help please I don't want tonsplashnoitnon a pump if it could be something more simple.
I drove the car again and after 10 minutes the inlet manifold is hot enough where you can't put your hand on it. It's annoying me now.
S3KO4
Ok everyone, thanks for your help after another long day, I took all the breather pipes off, cleaned them and repalced the pressure sensor, so far the car drives smooth and no more issues with the light. breather pipes were really messy all had original clips, at some point I will also remove the rocker cover to remove the build up inside it.
pressure sensor took a while to remove, had to remove the inlet min, oil feed to the turbo, and a metal bracket. all were on the oil cooler so pretty straight forward.
S3KO4
S3KO4
thanks dave.
superkarl
MAN OF STEEL
Excellent. What pipes did you take off? Were they pretty clogged up?
S3KO4
The entire breather pipes from the side of the rocker cover to the oil cooler, it was pretty bad, especially that pvc round thing on the top. messy job.
quattro1
glad its sorted mate! didnt have some helmet watching you from his smart car this time!? lol
