Bkd 140 and im not sure myself mate hence why i want to know what it isWhat engine?
Is that the camshaft position sensor?
Alright ill try that and see but i also want to know what part that is as im not too sure myselfI don’t think it is, I was wrong.
From your pic though I can’t really see any leak, just a build up of muck.
Give it all a good clean and check regularly to see if you can identify the culprit.
Ive took a much clear picture at to what i was on about.I don’t think it is, I was wrong.
I will have a look, i know i have a coolant leak as i have to keep topping up my coolant every few weeks. How would i stop the leak if it is around that plug?The round plug is for the injection system and glow plugs.
The silver bit in front of it is the tandem pump. Check all around that for leaks. Iirc to the rear of there is a temp sensor. A tiny amount of coolant may be spraying out, attracting the dirt.
Does it cost alot to replace?Would need a new plug, or as a minimum a new o-ring.
Oh whats the part called ill look it up. Also ive just found another leak around here its next to the egrNo they’re not a lot. Can’t remember how much I paid £20-30 I think.
I only say that cause on mine I had no external sign of a leak, no symptoms of a porous head but was losing coolant.
The only thing I could put it down to was the head or egr cooler. It ran fine right up until I got rid of it, just used coolant.
Its a 06 plate but it is a C revision i heard they relsoved the issues on them? Also ive found that my radiator is leaking, i need to replace the heater matrix too and a pipe which i forgot what its called but its behind the engine and coolant leaks out of it.Depending on the age possibly a porous cylinder head too?
I found these faults today i had my mate check my car up once he was freeUrmmm you didnt think to mention these to us initially mate or only just found the faults?
