Oil check valve kit, JHM spacer??
RACK Sep 17, 2015
  1. RACK
    RACK Member
    Seen as the intake manifold is going to be coming off in the next week or so I'm thinking of doing the oil check valves too, might as well seen as its all done then
    I've found kits from the states but is there anywhere over here that does them?
    If I order from the U.S. I'll prob get from JHM and go for the intake spacer as well, anyone else put one of these on, if so how was it?
  2. Avatar
    Google AdSense Advertisement
  3. RACK
    RACK Member
    So been on the phone to audi and all over the net
    The 2 check valves and the jet valve were about £78, tracked them down on a site called www.scuderiacarparts.com/‎
    And the same part numbers ( 2X 079103175C and 1X 079115540A) are about half the price even though they're listed for a Lambo!
    The other bits I was after (couple of o-rings and the plate) are pretty cheap though, so I'll get those ordered.
    Only thing now is the Pintle caps for the injectors, unless the inlet can come off all in one piece without taking the injectors out??
    Anyone??
  4. Darran
    Darran Active Member
    574
    86
    Which engine?
  5. RACK
    RACK Member
    It's the BBK one
    Found a UK supplier for the injector seals and pintle caps now :)
  6. Darran
    574
    86
    Lambos are owned and powered by Audi.A lot of parts crossover.
  7. RACK
    RACK Member
    Found that out earlier lol
    Got the valves fit about 25% less than Audi wanted
    The inlet gaskets for 50% less
    But got the pan gasket and o-rings from Audi as they were less than most places
  8. danharding42
    danharding42 New Member
    Hi Rack sorry to dig up an old thread.
    I've just got myself an S4 and looking at doing this work, could you tell me where you got the parts from please if you can remember?
