  2. Dismiss Notice
OE led taillight conversion
trance Nov 25, 2013
  1. K U L
    K U L New Member
    Anybody still active around here? Can you please help me with the problem posted above?
  2. Avatar
    snack-media
    Advertisement
  3. AU11 ALS
    AU11 ALS Well-Known Member
    719
    352
    Sorry I can't help, I'm in exactly the same situation... Have a pre f/l with led wanting to put f/l LEDs on an avant...
  4. Anees
    Anees New Member
    22
    17
    Me too.
    I have an S4 with pre-facelift LEDs and am looking to install facelift LEDs.
    Anees
    V6 Quatt likes this.
  5. T0m
    T0m Active Member
    516
    27
    I take it from this discussion that the B8.5 lights fit the B8 but depending on what pre facelift lights you have it depends on what connector and coding you need?
    Since seeing the new LED lights I am liking those over the ones Ive got so thinking this is going to be one of my first mods!
  6. A6tyy
    A6tyy New Member
    29
    Hi you have got to do coding regardless because the brake lights and headlight now run on separate wires and the connectors will be different too, pretty sure for the avant you can wiring loom from someone on the forums but Dnt think they from the uk but it's not too hard to do your own wiring just do the coding 1st the get a mate to go through the lights while you test what wire does what
  7. T0m
    T0m Active Member
    516
    27
    Thanks for letting me knwo mate, I would need to get someone to do the coding bit for me and as for wiring im not to bad but again I think Id like to get some help on that one when the time comes!
  8. dpaz
    dpaz Active Member
    525
    119
    43
    If you own a pre-facelift save yourself the hassle and money and just go for pre-facelift LEDs. Plug and play with small amount of adaptation coding.
  9. V6 Quatt
    V6 Quatt Well-Known Member
    1,278
    480
    How, what's the easiest method??
  10. V6 Quatt
    1,278
    480
    Me too
  11. dpaz
    dpaz Active Member
    525
    119
    43
    The facelift LED light units are physically a different size so don't fit in the pre-facelift boot lid. So means you have to buy a facelift boot lid and even then the fit won't be 100% unless you buy the facelift rear bumper as there is a small gap at the bottom of the outer headlight units. The facelift LED units also need additional wires running from the central convenience module as they are a more complicated wiring setup.
    Don't get me wrong, the facelift LEDs are a better unit as every bulb is LED in comparison to the pre-facelift which only have the tail/brake lights as LEDs but factoring the cost of a new boot lid, rear bumper, getting them painted then buying the cabling and connectors means its just not worth it. May as well put that money into your next car.
    The pre-facelift units fit perfectly and don't require any additional wires running from Central Conv.
  12. Avatar
    snack-media
    Advertisement
  13. A6tyy
    A6tyy New Member
    29
    After selling my old stuff my back end cost me just under £400 to me was worth spending that
  14. dpaz
    dpaz Active Member
    525
    119
    43
    Well done. Feel free to post up info on wiring and any other advice you may have for others trying the same retrofit.
  15. A6tyy
    A6tyy New Member
    29
    No worries as I said in walker posts it's all down to coding but any one who wants help is welcome to mail me as ppl on have done so already and I'm happy to help.
  16. dpaz
    dpaz Active Member
    525
    119
    43
    There is more to retrofitting facelift LEDs to a pre-facelift car than just coding. Extra wires need runing from module 46. Or did you fit facelift LED to a facelift car?
  17. A6tyy
    A6tyy New Member
    29
    No I fitted led face lift lights to a pre face lift car, it's an se. When I done the conversion I found it was important to change the coding 1st as then I knew what wire did what and then I added the extra wires in as it makes sense so you know what lights are doing what function. That's how I did mine any ways was done beginning of the year have had no errors or problems at all.
    johnnevett likes this.
  18. Ash187
    Ash187 Well-Known Member Gold Supporter VCDS Map User
    7,566
    818
    Sorry to dig up an old thread but i was pointed in this direction... if anyone wants the LED tails upgraded give me a shout as i can make up the looms and do the coding.
    Kalashnikov likes this.
  19. til
    til New Member
    Hi rs5uk
    Was looking to know if you still have the link to download for coding and wiring as I have done the conversion but need coding and wiring please
  20. DjLou
    DjLou New Member
    Please can you help me with the coding
  21. DjLou
    DjLou New Member
    Cheers Ash done a wicked job thanks for the help
  22. vw754
    vw754 vorsprung Durch Technik
    2,387
    hi guys,my mates got a 2011 pre facelift a4.(non l.e.d)........he's brought face lift led lights from a 2014 car inc bootlid.......any ideas on connection/wiring etc ?
  23. Ash187
    7,566
    818
    Bring it around to us and we can fit and code it
  24. xaixai
    xaixai New Member
    Hello
    I need your help.
    I retrofit rear tail led lights with kufatec wires, and already tried several coding, but never work like it does.
    When i turn the lights on i see the neon on and the brake lights on too.When i brake increase the neon lights...every other lights work fine.
    Can you help me with the coding for the brake and lights on?
  25. Ash187
    7,566
    818
    Send me a pm or email us on info@audi-retrofits.co.uk
    We can sort out the coding for you.
  26. robsey29
    robsey29 Member
    65
    Hi ash pm sent regarding coding as i am at a loose end.......
  27. robsey29
    robsey29 Member
    65
    If any one has the correct coding for pre-f/l led to facelift led i would appreciate any help as i am at a loose end.
  28. JG51 AUD
    JG51 AUD Well-Known Member
    3,350
    2,139
    @DJAlix
  29. robsey29
    robsey29 Member
    65
    Beer tokens
    Pm sent to him!
  30. robsey29
    robsey29 Member
    65
    I am still stuck with this the forum member above i have had not heard back from him. Has anyone else carried out this mod or is there anyone out there with the facelift led lights already fitted that can plug vcds in to get the coding data beer tokens your way of course!!
  31. DJAlix
    DJAlix VAG Car Coding™ Limited Site Sponsor Gold Supporter VCDS Map User VAG Can Professional ODIS (Offboard Diagnostic System)
    6,060
    4,645
    Apologies... Crazy busy, my inbox has exploded. I will be contacting you later today.
    JG51 AUD likes this.
  32. robsey29
    robsey29 Member
    65
    Nice one much appreciated
  33. Avatar
    snack-media
    Advertisement
  34. robsey29
    robsey29 Member
    65
    Did you get a chance no major rush if your major busy but just a reminder that you have not forgotton.
  35. DJAlix
    6,060
    4,645
    You have a pm :)
  36. robsey29
    robsey29 Member
    65
    Replied
  37. AU11 ALS
    719
    352
    Let me know if you need coding, we have B8.5 Rear LED units on our B8 successfully coded by a helpful guy in Leeds... if I can help I will if not I can pass details on to him
  38. AU11 ALS
    719
    352
    Hoping to have full Dynamic indicators in the next couple of weeks too!!
    Audigit likes this.
  39. Audigit
    Audigit Active Member VCDS Map User
    187
    65
    Is that using aftermarket lights or oem B8.5 units?
    Sent from my E6853 using Tapatalk
  40. robsey29
    robsey29 Member
    65
  41. robsey29
    robsey29 Member
    65
    Also would be very interested in this also if you have any info on how it's done. I am using genuine oem b8.5 units.
  42. AU11 ALS
    719
    352
    Using the OEM B8.5 units with custom circuit boards
  43. AU11 ALS
    719
    352
    I should have all the parts next week so in a week or two hopefully be able to advise further
    It's not going to be cheap though!
