Occasional dsg clunk
skiptowncat
I've been having intermittent clunks during gear changes and have narrowed it down to only happening when I'm off throttle.
If I'm on the accelerator it will change extremely smooth.
If I accelerate then let off it wil clunk into the next gear up.
Does anyone else have the same, I'm hoping it's a mount issue rather than the gearbox itself.
benjie
What does the sensor calibration do?
razza1
Lol, love that, wonder if it would help with mine in anyway...
razza1
Did you do any calibration driving afterwards? Has it improved downshifts?
skiptowncat
Yes, did some manual shifting at part throttle and then some wot blasts. It has significantly improved 1-3 shifts both up and down.
Reversing uphill from a standstill is very snatchy but I'm hoping it will adapt.
benjie
Just found this on another site, might be of help in explaining why the distance sensor calibration didn't work. Might give it a go on mine, though it's pretty smooth as it is, but I think it pays to keep stuff like this calibrated regularly.
Basic Setting, 0B5 S-tronic Transmission
- Before starting, please see 'Notes' below
[Select]
[02 - Auto Trans]
[Basic Settings - 04]
- From the pull down list select one of the following at a time, press
[Go] and when it has completed press [Stop].
[Erase counter for start and stop processes]
[Clutch valve calibration]
[Distance sensor calibration]
Test Drive, check for fault codes.
Notes:
(Kiss points)-Prerequisites: Engine idling, transmission in P and
transmission oil temperature 40°C - 100°C.
Prerequisites: Engine idling, transmission in P and transmission oil temperature 40°C - 100°C.
Prerequisites: Engine off, selector lever in P.
benjie
Sorry yes, I meant that one.
