That looks like a good idea.Home
obdeleven.com
The pro pack comes with 24months plus some magnetic thing.
Not sure how good a deal this is but in the excitement of waiting 2 months for my car (!) I've bought it.
Can anyone in the know tell me if this is suitable for a novice to use? I'm thinking of the electronic interference programs being turned off. Or it is better to have a company do this for you if you've not used a device like this before?
Thanks, that makes sense. So when adaptations are made, can they be seen by Audi? I'm just wondering how they'd view changes to the systems. Any thoughts?Turns off lane assist to remember last setting ok
Be wary of using the ‘one click apps’ though as it’s not 100% return to previous state should it screw up….
Problem here is it’s not showing what it actually changes in ‘One Click Apps’.
If you are familiar with adaptions ‘ala’ VCDS then at least you can make changes that way and actually see what you are doing.
If you went VCDS route (you’d need OBD11 to unlock SFD anyway) VCDS logs every coding and adaption change you make, and you can make an adaption channel map / auto scan.
I’d love to buy this for use on my S3 and would like to use the one click apps as I think that’s about my level however when I go through the OBD forum it appears none of them work for the users. Anyone know why? Don’t really want to spend out for something that might just be useless.
My plan was just to use it for long coding.
I had vag-com from back in 2003 last time I did this sort of thing.
From my understanding, take a back up of your car as soon as you get it.
And only long code stuff very carefully. Taking note of what you're changing before you change it.
I've seen some of the one click stuff on YouTube. Eg Scandy DRLs. But I'm guessing the apps are just macros. So you can do the same manually.
As with lots of things. Before buying this YouTube is your friend.
So a waste of money right now then.Half the ‘one click apps’ aren’t available for the 8Y.
Probably because the way certain ‘features’ are changed on the 8Y is totally different to an 8V and either have been removed by Audi (lock when running springs to my mind) or the adaption/procedure has been changed
