OBDeleven/Coding
RS03???
RS03???
Mastachaz
RS03???
Not possible via coding now.
I am sure, you will be the first to advise on how. Hope you had a good break.
RS03???
8YARWY
Testing Testing Testing.......1..2..3
I had one on my 8V.
Quite a bit smaller and was easier to get back in the hole.
Mastachaz
I've got one of the start stop devices, took all of about 2 minutes to install and has been working well for the last 2 weeks
Same seller ? i want order one so.dont have to put it.off all the time
Mike.46
Well-Known Member
A9 Soundaktor
What's the setting std? I'm sure I read 100% on here somewhere? mine was set to 80%
Mike.46
Well-Known Member
Is this able to be altered using VCDS, sorry I'm still learning what's what.
Yes, but doesnt come up under installed modules, once searched for it appears, just search A9, you can alter the % 'noise'
Good sound to be honest and very like it should sound, the one on my Golf R sounded like a cross between and RS3 and a scooby so I turned it off
RS03???
I had one on my 8V.
Must be a tiny microchip emulating a key push after 3 secs after power-up, or similar power on delay pulse.
8YARWY
Was a tiny module about the size of a thumbnail. Worked well though.
Now I just have the SS wired to the ASR module.
One thing to note though, anyone who has Ghost immobiliser can have SS disabled that way.
RSt3ve
Well-Known Member
I've just done this today, might be in my head but the sound seems cleaner/more defined, almosy like it was semi distorted before, really happy with it, cheers.
8YARWY
I’ve found 50% with ASR I can hear more external exhaust sound.
Had the neighbour ask what happened to the car to make it noticeably louder yesterday
RSt3ve
Well-Known Member
I should've been fitting the ASR today but the missus didn't hear the door yesterday, so Monday. Sounds promising though.
satoone
Hello all
I asked everywhere but still no luck and really need help
This RS runway display is locked on Japan version so even if you press the RS button only normal display
shows up and even on MMI when you chose display only 2 choices can be selected and is shown
Anybody can try to tell me where I can find the RS runway display coding area so I can try to unlock?
Or second solution provide me a copy of the OBD back up so I can compare with mine and define the area where it is locked?
All help appreciated
8YARWY
Hello all
It’ll be locked by firmware. Nothing that OBD will be able to change.
Hello all
Yeah for some odd reason some markets receive different MMI layouts and features, where I’m from we also don’t get the runaway layout.
Mastachaz
it;s nothing special :)
3vans
Just noticed ODBeleven Pro pack on special deal until tomorrow on their website plus £21.72 shipping. Seems a good deal?
F8BA28A1 3DB8 4695 9E8E 73D001CD5B9C
I don’t really recommend, 90% of the codings don’t work for the 8Y and even ones they say they do (for example disabling the headlight washer doesn’t work and plenty more), if you want to code get vcds, but you might need it for unlocking some things to access them using vcds ( @8YARWY is the guru so ask him for more detailed explanation I haven’t done it haha)
8YARWY
It’s a rip off as I’ve been saying all along.
Only thing it’s good for is unlocking SFD but even that has other work arounds now.
MikeTV
I recently bought OBD11 pro and works fine (8v s3)
- added the audible alarm blip
- removed fake exhaust (soundaktor) sound to 0%
- increased throttle pedal (however can’t really notice a difference)
- increased comfort turn signal from 3 to 5
- mirror dip
the above in itself is worth the money for me but each to their own
8YARWY
- mirror dip
Maybe semi ok on 8V platform but the fact still remains that on the 8Y it’s rubbish.
K44WMY
Guys how can i remove the mmi message when you start car? Privacy statement message. The do not show again is greyed out.
Also how can i input address into sat nav keyboard when moving? As a passenger its annoying as its greyed out.
RichK
When driving it won’t let you type, safety feature I believe, you have to use voice, can’t recall if you can drawer the letters though. Agree it’s annoying as your passenger can type!
K44WMY
Yeh you have to draw it which is a pain. Bigger unsafe feature. Can it not be sorted via obd11 and the message at beginning?
Mike.46
Well-Known Member
Yes, PITA that the passenger cant use the type function, voice activation is not bad though
8YARWY
I had a good look around in 5F yesterday and there’s nothing in adaptions to alter the Nav input
