  2. Dismiss Notice
O2 Lambda sensor fault code P0130 01/01
RS3 ROCKS Feb 10, 2020
  1. RS3 ROCKS
    RS3 ROCKS steve
    340
    Hi all just a quick post regarding advice on the fault code P0130 01/01. This was using a generic OBD II reader. I have no access to VAG Com.
    Looking online the fault code is the Lambda Sensor Bank 1 oxy sensor. I've found a handy video from an APY TT showing the removal process. This shows it as a pre cat lambda sensor. Can anyone advise on the correct part as it seems a minefield out there. Checked euro car parts and they have a miriad of different options.
    Also do I require a lambda sensor double depth modified socket or can i just use a crows foot socket?
    You tube vid is below along with euro links. My engine is an AMK 2001 210bhp
    Thankyou
  2. Avatar
    snack-media
    Advertisement
  3. RS3 ROCKS
    RS3 ROCKS steve
    340
    Update from original post
    Audi have quoted£223,84 for the bank 1 sensor 1 lambda sensor pre cat.
    This is well above what I can afford having spent so much on parts to keep the car running already.
    Can anyone provide the oem pt no please for an AMK so I can source a cheaper Bosch item? Audi no longer provide pt nos
  4. AGB-S3
    AGB-S3 Registered User
    545
    47
    All the engine sensors are bit $$ , the turbo inlet temp is £270
    as is the lateral accelerator sensor ,
    I suspect the problem is , the engine management is pre , '' sensor calibration code''
    so they need to be more accurate than the modern ones , that come with a
    calibration 'code' so can be any old junk as long as it calibrates on final test
    and the system prints out a code .
    the new pre-turbo temp sensor has detachable probe , much cheaper ..
    and of course , never miss a commercial opportunity ,
    audi Versus VW pricing still about ?
