G
Try shock tactics, hot then cold. I used a blowtorch to heat it up, sprayed penetrating oil as it was cooling down. You may have to do this 3 or 4 times but it will come free.
I've changed a few and none came out straight away, had to use the hot and cold method. If it's a newish car then maybe they will just unscrew first time.
I think S1 B1 is the passengers side one and by taking the airbox out it made it so much easier but its its still stuck.
Frakenaudi has won !!,
So over the weekend I injured myself in a non car related way (chipped a bone in my right elbow) , this morning I thought I would have another go at undoing the correct sensor this time . Wow there is even less room !!, maybe 3-4 inches maximum.
So I have the correct removal tool but standard ratchet , Im not the smallest of people weighing in at a very tiny 18 stone , so laying across the inlet manifold was ummm an interesting experience (at least if nothing else I can demonstrate that the inlet manifold can support 18 stone !!).
Having watched "whodafunks" excellent video again I set to with new enthusiasm , with the socket properly in place (Im also a left hander - please don't burn me at a stake !!) and held down with my right hand I hauled mightily on the ratchet and promptly snapped the ratchet to socket adapter !!, quick change to 1/2 inch and try again , I could have sworn it moved ever so slightly , so surely it must break loose next time right .
Wrong the ratchet snapped back with so much force it jammed my little finger between it and the edge of the brakebooster, result blood everywhere and a broken little finger !!.
Down but not out ....this muthafatha ain't going to win, no way no how , it won the battle (this time but it hasn't won the ****** war !!!)
I know that normally the mechanics to loose the tension from bolts (locking nuts) on wheels they tapping on socket and then unscrewing them, but dunno if wouldn't (in worst case) damage the exhaust manifold bolts -> unsealing manifold.Get some brake cleaner and spray it around the nut (when it's cold) and try and get rid of as much crud as you can with a wire brush. Then try and get some WD40 in around the join between the sensor and the downpipe and give it a few minutes. You could even try tapping the nut at each side with a hammer to loosen up anything causing it to stick. Then get your socket and ratchet on it and give it some elbow
