6 bulbs in 4 weeks? That sounds like remarkably bad luck, are you sure it is the bulbs? Sounds like you might have other issues, dodgy contact somewhere? Are the bulbs definitely fried? Can you try them in another location to test?
Just manage to do mine by breaking the lens around the screw and then using pliers on the screw. Thanks for the recommendation on the allen screws guys, hopefully won't see this issue again.
After reading this thread I came very prepared with all the tools before i started the job. Drilled the hell out of the lens around the screw then at an angle underneath it. Not the tidiest of methods but got the job done after a bit of "gentle" persuasion. Then replaced with a decent set of leds as recommended further up. Very happy.
Fitted mine yesterday, my screws luckily wasn't locked up, i removed the light units, cleaned the lens's and refitted them but the contact ddin't work at first so i had to have a good play about until they worked.
LED Lights by Ste Topping, on Flickr
Followed directions of Leaky Lloyd. Took longer than 10 mins and will have to replace the lens & put in hex nut screw in case I or next owner has to replace it again.
thanks for all the advice, with lots of care and L shaped screwdrivers I managed to remove one of the 'soft' screws without rounding off. the other rounded :-(
However on the 'succesful' side when I levered the lens of, the inside crumbled, all rotten.
