Not happy
MPP
South Wales
Just got back to the car and someones hit it and driven off. Dented the wing right on the arch.
I have know idea how it's going to cost to fix.
Mrs is gutted. she's had it 2 years without marking it.
I'll put pics up late
take it its front wing?
prob looking £150 tops as its only a small wing would be cheaper to buy a used one
That what I'm thinking. Just need to make sure the wings are the same 2004-2006.
all wings before the 8P3 are the same. 3drs and Sportbacks are also the same.
sorry to hear matey!
Sorry to hear that. Hopefully a PDR specialist can do something with that, there are a couple of wings on ebay as well, in red. "A3 wing" brought them up. Hope it gets sorted easily.
im no expert, but a decent bodyshop should be able to pop that back out i would have thought, my dad had a much worse dent then that on mis old car, not an audi, but they were able to pull the dent out. has there been any paint work damage?
get the car to a paintshop, that will set you back between 100-180 quid to sort and it will be quick
in answer to your earlier question 2004-2008 wings are all the same regardless of sportback or 3door
Id check out a dentmaster. You would be very suppriesed what they could pull out! New wing from dealers would cost you around £100. But that looks like an easy fix for a body shop so doesnt look like you need a new one
no way does that need a wing! dent master could get most of that out but it wouldnt be perfect as its creased on the crease i you know what i mean?
A bodyshop would pull it out, light skim of filler and spray it in. £200 tops
yep agree with others. My daughter had a nasty dent in the back panel of her toyota. a Local expert managed to fix it. They use what look like long knitting needles and gently press it back from the inside , not a mark even the paint looks sound. That was about a year ago and it cost about £90...
I had a very similar dent that the body shop repaired rather than replacing the wing. Hope you find someone local to sort it.
14
942
