  2. Dismiss Notice
Not another Nogaro!!!
IPG Jun 16, 2016
  1. tcg
    tcg Well-Known Member
    909
    439
    Almost there mate,not long before you're greeted by a bouncing Noggy,maybe 'borrowed' from your sig.
    :nogarors4:
  2. Avatar
    snack-media
    Advertisement
  3. IPG
    IPG Well-Known Member
    1,841
    778
    Hahaha that would be a fun feature.
    They do have an enimated screen saver (like that 3-d word that you can customise in windows 98!!!) so I think it's totally capable for an animated boot logo. Just have to somehow make they happen!!!
  4. tcg
    909
    439
    I'm sure a man of your calibre will :yes:
  5. <tuffty/>
    <tuffty/> Badger 5 Edition...Its all about the flow... Staff Member Moderator
    24,171
    5,507
    does this bit of kit support navigation?...
  6. IPG
    1,841
    778
    So far - no. But the firmware can be flashed so I guess they can develop it. Is the deal broken without it :p
    I've contacted the Russians with this question. Will report back.
  7. <tuffty/>
    24,171
    5,507
    Pretty much lol
    Nice one...
    Just updated the firmware of my FIS Control and seems to have the feature I asked Stefan for where you can build displays of individual measurements from different blocks (called collections in FIS) so I can have AFR, EGT, IAT, Coolant temp etc all in the same display... just need to work out the slightly 'interesting' way to get labels onto the values (like VCDS does)... he has a web page you upload an output file from and label everything up on that... export then flash back in... bit round the houses which is why I haven't bothered yet :)
  8. IPG
    1,841
    778
    Yeah I think for custom stuff you gotta go a by around the houses but that's when you get what you want.
    Ahh well. Maybe they'll do the navigation feature soon. But I just use my double DIN HU for that.
    The only things missing here are oil pressure and AFR
    Unless there's a MB for AFR then you can just choose it in the diagnostics options
  9. Dohcwp
    Dohcwp Setting the Standard
    296
    151
    43
    is this also able to show the selected gear for auto models like its displayed on the red fis
  10. S3 Hilife
    S3 Hilife It's an addiction Gold Supporter VCDS Map User
    968
    593
    93
    Can you not use external sensors to display other information like you can with FIS control?
    I've messaged the Russian about buying a couple but I think he's been especially busy since you've posted this
    Steve
  11. IPG
    1,841
    778
    M
    Yeah most likely. Since it goes through the years in the manual.
  12. Avatar
    snack-media
    Advertisement
  13. IPG
    1,841
    778
    That would be good!!! Did you ask him ?? I asked about the navigation thing...
    Yeah he had not been inundated with an order of 20 from the USA. I have an order of 15 to ask him about. LOL
  14. <tuffty/>
    24,171
    5,507
    AFR is block 032... request and actual... (http://www.ross-tech.com/vag-com/m_blocks/)
    That is one thing the FIS does well though... you can add external sensors like AFR, oil pressure, oil temp, EGT etc and display it in the DIS..
  15. S3 Hilife
    968
    593
    93
    Yes I did ask him mate, just waiting for a reply but I'd be surprised if it doesn't support it.
    Wow 15 units, sounds like you'll be the official Oz distributor
    Steve
    IPG likes this.
  16. vtecas
    vtecas Member
    32
    Wow great news!!
    Does this work with the pre face-lift (apy) and with the fis controller??
  17. IPG
    1,841
    778
    only oem navi on a6c5 at this moment/ now under tests
    I think it will - I was able to swap a facelift cluster into a pre facelift car. They both have the same set of plugs and everything worked fine. So I don't see why not.
    Can anyone clarify the clusters only are cosmetically different? Because that's all I can see is the difference... the dials faces.
  18. <tuffty/>
    24,171
    5,507
    not explicit confirmation but... I believe there are several variants... some have two plugs in back, some three... there are also variances in manufacturer I believe.. VDO being the main one but there are others IIRC..
  19. Dohcwp
    296
    151
    43
    think its only going to work with pre facelift canbus clusters so its those that start with 8l0 920 the 8l0 919 non can clusters (like mine :crying:) wont work from what i can decipher from the russian site. can clusters have the grey connector at the back, non can has the 20 pin red connector instead
  20. IPG
    1,841
    778
    ahhhh right thanks boys
    that's the thing - i've only ever seen the three plug clusters down in Oz.... maybe you guys have the early early production ones with the blue and green and then a different centre plug.
  21. IPG
    1,841
    778
    i just checked my pre facelift cluster - you are correct with that part number
  22. Dohcwp
    296
    151
    43
    Ian you can add this to your guide (for those with questions if the colour fis will work on their clusters) (not hijacking your thread lol)
    Pre Facelift Non canbus Cluster begins with 8LO 919 (has analog clock) WONT work with Colour Fis (there is some rare anomaly 920 pre facelift clusters with analog clocks but they wont wont as they dont have the grey connector even though they might have a can engine signal on the green connector, Immo 2)
    Pre facelift canbus Cluster starts with 8LO 920 (Digital clock) (essentially a facelift clock that they fitted in the last of the Pre facelift models), after production/manufacturing was stopped on the older clocks (Can Clocks will have the door open signals on the fis, Immo 2/3) will work with colour FIS
    Facelift Canbus Clocks (same as pre facelift, just different foils with new S3 logo and some internal circuitry revisions, also Immo 3) will work with colour Fis
    Non Canbus Back (20 pin Red connector)
    Canbus Back (Grey Connector) think its 32 pin if i remember correctly
    Roadtrain likes this.
  23. vtecas
    vtecas Member
    32
    OK cool, so mine is a pre face-lift with digital clock. It will work :rockwoot:
  24. IPG
    1,841
    778
    Nice work!!! That explains it all
    I'm not sure if I can edit that into the guide though... guess I'm copy and paste into a new post.
  25. IPG
    1,841
    778
    Nogz started making funny noises.... so of course... i need to investigate...
    Off....
    Off
    Roadtrain and tcg like this.
  26. Dohcwp
    296
    151
    43
    Damn thats motivation i wish i was able to attack my car on such a level.
  27. IPG
    1,841
    778
    First time i've done this stuff so wish me luck! hahaha
    ...hrmmm.....
  28. tcg
    909
    439
    On reflection?
  29. Dohcwp
    296
    151
    43
    bits of metal ?
  30. IPG
    1,841
    778
    Bingo
  31. IPG
    1,841
    778
    What even is this gunk!!??? And how did it get all the way in there!!!
    Cleaned that shize right off!!!
  32. Roadtrain
    Roadtrain Audi S3 8L 225 "BAM" from Italy :)
    233
    32
    It seems sawdust?!
  33. Avatar
    snack-media
    Advertisement
  34. IPG
    1,841
    778
    It's like grease - solidified. It's in all sorts of places in the engine bay! :( needs a clean...
    Clamp has come loose = MORE cleaning
    Just to remember how this goes
    This crustyness needs to go!
    RIP seatbelt
    Gearbox "nut on bolt" bolts out
    Had to remove this guy for bevel box access
    Drain the blue **** out
    Seatbelt came in handy!!!
    Clutch and flywheel off (think it's time to change?)
    This bolt was NOT my friend!!! *sigh*
    On stand and good for some open heart surgery
    Just some of the parts that have been removed
    Gotta leave maybe 6 hours a weekend to work on the engine since there's study and work to do. Hoping it'll be a slow but steady progression to the final setup!!!
    Stuart B and <tuffty/> like this.
  35. Tj 0785
    Tj 0785 Well-Known Member Bronze Supporter Silver Supporter VCDS Map User
    3,588
    1,060
    Any idea on cost of fitting by you or the company I'm very interested in getting this
  36. IPG
    1,841
    778
    I think you can send your cluster to russia for them to do it but not sure what logistical costs there will be.
    Same for me. I could do it but it would cost a bit to get it to me and back swiftly. Labour would be the biggest part... it's not a quick job like replacing the OEM screen. Of course. If you want it done. Just PM me and we can sort something out if there's no one on your side of the pond that is game enough.
  37. Stuart B
    Stuart B Well-Known Member
    3,448
    743
    did you manage this all with a 13mm spanner and long nosed pliers?
  38. Tj 0785
    3,588
    1,060
    I can't even figure out how to email them let alone ask how much to instit ha
  39. IPG
    1,841
    778
    Of course! Hahaha
    Oh and a Stanley knife.
    Use google chrome as your browser so you even have half a fighting chance of understanding what is going on in the website. You need to make an account on the forum. Ordering details are on the multimfa or colormfa pages. Basically through PM. Just click around. You will find it.
  40. tcg
    909
    439
    And to think you were questioning your ability to change your oil pump :blink: you charlatan!
    You're way above that level of competence looking at what you've done ripping out the engine mate :yes:
  41. IPG
    1,841
    778
    LOL
    I've just never done it before so I ask questions to try get my head around it before I delve in
    Just the wierd way I work :blink:
    tcg likes this.
  42. Tj 0785
    3,588
    1,060
    I spoke to them today they will fit it for an extra 30 usd, seems like a lot of work for $30. But il be getting this done . Thanks Ian for offering
    IPG likes this.
  43. Stuart B
    3,448
    743
    you've missed a trick their TJ - you could have got the 30 people wanting the update and sent them all off to Russia for £150 each ;) new engine paid for in 3 weeks.
