- Joined
- Apr 22, 2015
- Messages
- 721
- Reaction score
- 76
- Points
- 28
Might be a silly question , [ bam]
If the turbo is on its last leg's, , are they prone to making any kind of noise ?
expected life ? [ 180,000 miles refurb etc possible ?]
Im getting, what sounds like a rustle , hiss or something akin to a motor with worn bearings
emanating from behind the center dash/glove box area ,
link with the turbo, appears the noise is linked to throttle opening and , slight delay and engine revers , needs to be 3500 4000 for it to show , then its related to amount of T opening
Car is driving normally , no engine lights etc , which is slightly confusing , am I hearing the
dump/boost valve operating for example and if so, why is it a new noise , conversely may be it was not working before, the car has a aftermarket valve fitted . thought the boost pressure showed 1 bar on the vag , never been any lack of pressure flags
actually engine .may actually be making more mid range power than before .. may be its working properly ..now ?
any thoughts ?
Tnx-G
any thoughts ?
Tnx-G
