Lukeyb
- Joined
- Oct 21, 2008
- Messages
- 397
- Reaction score
- 53
- Points
- 28
I came across this issue with my A3, you can turn the heaters up all the way and its still just cold, the AC will make things even colder, but cant get hot air.
Ive felt all of the hoses and they all get hot when the temp needle is up to 90, so the thermostat is opening and sending flow through the radiator.
Ive also left the cap off with the temp on HI to see if there was an airlock in the heater matrix.
Ive read that there is a flap that controls the hot/cold and possibly a valve to control flow, but cant find how you would check to make sure its actually all working.
VCDS comes up with no faults and there are no other issues to report, just these cold heaters.
Is there any output tests or the like you can do with VCDS on the climatronic unit?
Any pointers would be appreciated
